Help with Shocks!!
Old May 19, 2015 | 06:46 AM
JKLove's Avatar
Veteran: Marine Corp
Default Help with Shocks!!
Of course, I am a new jeep owner and new to "DO IT YOURSELF". Can anyone tell me what type of shocks these are and perhaps recommend a decent operating and looking replacement?
ID:	611400Click image for larger version
many thanks in advance!!
Old May 19, 2015 | 07:11 AM
Rancho's Avatar
Sponsoring Manufacturer
They look to be a monotube of some make.
Many people like our adjustable RS9000XL shock, you can have a soft or firm ride when you turn the knob.
Also our Spring rebate is going on, so save some money.
Promotions
Do you have a lift? We offer different P/N's for various heights.
Also install isn't too hard, rears are easy.
Fronts are a bit of a PITA.
The top bolts are just not fun.
Good luck!
Attachment 611400Attachment 611401
Old May 19, 2015 | 07:32 AM
D_engel's Avatar
theyre rough country. Replace them with the Rancho 9000xl's. youll be pleased with them.
Old May 19, 2015 | 09:47 AM
JKLove's Avatar
Promotions
Good luck!
I know this might be a really dumb question. But, how do I know if I have a lift?
Old May 19, 2015 | 10:03 AM
NJKURPat's Avatar
Take a couple pictures of your jeep from the front and side, most of us here can tell the stock ride height from a picture. Also take a picture of your springs, and the top of the spring so we might be able to tell if there is a spacer puck. Are there any other upgrades done (bumpers, tires, etc.)?
Old May 19, 2015 | 10:23 AM
Rancho's Avatar
Also (sometimes this can help) what size tire do you have?
Old May 19, 2015 | 10:29 AM
JKLove's Avatar
I will take a bunch of photos this afternoon and post. Appreciate the help.
Old May 19, 2015 | 11:39 AM
Invest2m4's Avatar
Best way to measure lift is using the factory measuring points and seeing how much you differ. See pics.
Name:	Lift height.jpg
Old May 19, 2015 | 12:14 PM
nthinuf's Avatar
Since you have RC shocks, it's probably a good bet that you have a RC lift. Once you post a few pics we can probably point you at the exact lift on their website.
While you are taking pics, get one of the pitman arm and the upper trackbar bracket (to see if you have a drop pitman), the front control arms (to see if they are stock/fixed/adjustable), and the bolt at the axle end of the front lower control arms (to see if you have cams).
Old May 19, 2015 | 02:17 PM
JKLove's Avatar
Here is a pic of the front: Click image for larger version
ID:	611472Click image for larger version
Here is a pic to the front view: Click image for larger version
Here is another angle: Click image for larger version
