is this jeep lifted? Need help fast !!!!
Old Jun 17, 2015 | 03:20 PM
rj'sjeep's Avatar
Default is this jeep lifted? Need help fast !!!!
I am thinking about pulling the trigger on this the price is good mil;es are high and not sure if it is lifted the shocks look stock but he space above the tire to the wheel well is large these are 285 70 17 ties so the same as stock.. What can you guys tell?
Name:	blue  jeep IMG_5116.jpg
ID:	615140   Click image for larger version
Name:	blue jeepIMG_5112.jpg
ID:	615141   Click image for larger version
Name:	blue jeepIMG_5113.jpg
ID:	615142   Click image for larger version
Name:	blue jeepIMG_5114.jpg
Old Jun 17, 2015 | 03:29 PM
JE8154's Avatar
It's got a budget boost
Old Jun 17, 2015 | 03:30 PM
NJKURPat's Avatar
From the pictures it looks like there could be a spacer puck.
Old Jun 17, 2015 | 03:36 PM
nthinuf's Avatar
Yellow Arrow - the spacer they are referring to.
Red arrow - that upper bumpstop extension says TeraFlex, correct? Should narrow down whose BB lift is on it...
jonb1032's Avatar
Default Lift
Clearly has a spacer lift, looks like a 2.5 ", but it does look pretty clean down there from the one pic.
Old Jun 17, 2015 | 03:37 PM
TripleBJK's Avatar
I also see a teraflex rubber bump stop. Looks like a teraflex budget boost. I Google the spring #, it is a stock mopar spring
Old Jun 17, 2015 | 03:43 PM
TripleBJK's Avatar
It looks like a rubicon? What year? How many miles? How much?
Old Jun 18, 2015 | 02:27 AM
101gargoyles's Avatar
Former Member
High miles and that clean underneath? Th previous owner only drove his lifted JK through the cleanest of mall parking lots.
Old Jun 18, 2015 | 07:09 AM
TJinaJKU's Avatar
What they said.
Fyi, And 285/70 r17 are not same as stock. Close in height but about 30mm wider (first number indicates width in metric sizes) second number is the ratio of the width to sidewall height.
So it's rated as 285mm wide and (285mm x .7) x2 plus the 17in rim tall... Or 32.7x 11.2 inches (actual height varies similar to standard)
stock is 255/75 17. Which is 32x10inches
