LOD Bumper-finally
Old Jul 16, 2015 | 03:27 AM
stevedolce's Avatar
Default LOD Bumper-finally
ok--i pulled the trigger on the LOD rear..yahoo!!
i got the square cut out light holes..HOW do you mount those lights to the bumper? are there mounting screws from behind?
aside from rigid, what make of square lights are folks using?
Old Jul 16, 2015 | 03:53 AM
Cedo Nulli's Avatar
LoD has cut/drilled the bumper to accommodate the Rigid FLUSH mount Duallys/D2s. The flush mount version has a flange with four bolts that mount the light to the surface of the bumper. Extremely simple/clean install with the bumper already cut for it.
Old Jul 16, 2015 | 03:30 PM
stevedolce's Avatar
Thanks Cedo-do u have the rigid lights on a separate switch? Or do they turn on with the backup lights?
Old Jul 22, 2015 | 12:33 PM
Cat Dr.'s Avatar
Default Rear Lights LOD bumper.
I used a switch with a relay. The lights come on in reverse thru the N/C contacts of the relay. I use a switch to turn them on as needed. The switch actually energizes the relay. Mounted the relay behind the right break light assembly. Works great.
Old Aug 12, 2015 | 11:48 AM
stevedolce's Avatar
Got my tracking number!!!! Just a few more days!
Old Aug 12, 2015 | 01:02 PM
ACJK22's Avatar
Great bumper! I've had mine for 2 months and love it. Looking to get the light weight front bumper next from LoD
Did you do the carrier as well? I have the one that attaches to the door.
Old Aug 12, 2015 | 01:57 PM
TripleBJK's Avatar
Why did it take a month to get? I'm looking at ordering one myself. Is that the lead time?
Old Aug 12, 2015 | 02:31 PM
Albino Lizard's Avatar
If it has to be ordered from LOD it can take 4-6 weeks. My sliders took a full 6 weeks before they were at my door.
Old Aug 12, 2015 | 04:18 PM
htm7765's Avatar
Yeah mine took about 4 weeks " made to order " I was told but it's well worth the wait !
Old Aug 12, 2015 | 04:21 PM
twinz33's Avatar
I have nothing bad to say about the quality of lod's rear bumper which I have that with the latched tire carrier. Customer service is what I would call above average. Not as good as northridge but good. I've only had it a few weeks. Now that being said I'll add it took 13 weeks to get the entire assembly. One it came powder coated and I asked for it not to be but no big. I needed an 8lug carrier for the wheels and was told it was definitely made that way for me and it wasn't ... After 4 weeks I got that (total time is still 13weeks). Last if you have a wheel with 3.5in back space then expect to modify the carrier to work. My trail ready 17x8.5 with 40x13.50 Toyos and 3.5 backspace did not sit completely up against the carrier as designed and I tried every mounting position possible. After some cutting, grinding, painting I made it work Just my experience but not everyone's
