Backup Camera placement?
I fabricated a mount for my back up camera that is mounted on my license plate. Here is the write I did.
https://www.jk-forum.com/forums/jk-w...resent-332876/
R/
Will
R/
Will
I have my license plate mounted in my spare and wanted the camera a bit lower besides.
I ran the wires through a grommet below the stock jack and attached to the receiver on my aftermarket bumper.
This location also makes it easy to back up to a trailer.
It stays put with three little magnets for several years now.
I have my license plate mounted in my spare and wanted the camera a bit lower besides. I ran the wires through a grommet below the stock jack and attached to the receiver on my aftermarket bumper. This location also makes it easy to back up to a trailer. It stays put with three little magnets for several years now.
Flush mount in stock bumper. Use a step bit so you can make the right size hold in the front. Then you need another hole in the back to get the wires through. Then slit rubber plug in the jack storage spot and run wires up into jeep from there. Tap power from the right trail light harness under the plastic trim.
