Ram install
Old May 2, 2016 | 06:39 AM
Noroad's Avatar
Default Ram install
Finally got around to installing my Ram assist this weekend!
Name:	on the lift.jpg
ID:	645748   Click image for larger version
Name:	box first out.jpg
ID:	645749   Click image for larger version
Name:	box wholes drilled.jpg
ID:	645750   Click image for larger version
Name:	box fully tapped.jpg
ID:	645751   Click image for larger version
ID:	645753   Click image for larger version
Old May 2, 2016 | 07:34 AM
JKBud's Avatar
Looks good. I'm pretty much done with my install, I just gotta hook up lines to my cooler and ram.
Old May 2, 2016 | 08:46 AM
Noroad's Avatar
thank man! thats not to much left u are almost done!
Old May 2, 2016 | 09:04 AM
ttechris's Avatar
Nice install! What ram are you using? I wanted to do the Ram assist on my new JK, but it appears PSC no longer sells the 1.75x6.75 cylinder I used on my last build.
Old May 2, 2016 | 12:57 PM
Noroad's Avatar
thank you and I have 1.5 x 8inch PSC
Old May 14, 2016 | 09:53 AM
JKBud's Avatar
What box do you have? I have a West Texas one and trying to figure out if I have my lines backwards or I need a new pump. I hooked the top port to the far side of the ram and the side port from the box to the closer side. Turning at idle is slightly tough but not horrible.
