Regearing my jk
Old May 6, 2016 | 04:37 PM
bryns15jk's Avatar
Default Regearing my jk
I have a 2015 Sahara jku that came with 3:21s. I was Gna re-gear ton4:10 but I know the older axles, if u went from 3:42 to lower like 4:10 then you had to get a new carrier. I'm kinda on a budget so if I can go 4:10 with the stock Carrier then I'm good. Any input would be great.
Old May 6, 2016 | 04:40 PM
Jonathan_JK's Avatar
Your going to need new carriers. Honestly I would just save a little longer throw front and rear lockers in with the re-gear and I would recommend new axle shafts but the OEM ones are fine.
Old May 6, 2016 | 04:43 PM
bryns15jk's Avatar
I'm running 305/70-18 right now n it's gutless. I had stock tires n tried pulling a trailer with a medium size tractor n it was gutless. Which I am to expect with the current gearing.
Old May 6, 2016 | 04:49 PM
Loaded carriers cost around $200 or less. An E-Locker carrier cost around $900 for the rear and $800 for the front. I gave my front open away to a friend that blew his. But I do have a Rear 44 open loaded with 9K miles on it.
*Edit*
I'm going to list it on Ebay I'm only a (106) but I am a Top Rated seller
Name:	44 Carrier.JPG
Old May 6, 2016 | 06:34 PM
Chuck-The-Ripper's Avatar
Just a heads up, the rear is good for any ratio it's only the front that had the ratio split
Old May 6, 2016 | 06:40 PM
Yep your right he only needs a front
Old May 6, 2016 | 10:30 PM
Slowpony46's Avatar
Like they said, you only need a new front carrier. The rear is the same for all ratios. If you want to keep the front differential open like it is now, an OEM Spicer carrier for the lower ratio is less than $80 from a few places, so it's a minimal cost compared to the gears and labor.
Old May 7, 2016 | 12:52 AM
nthinuf's Avatar
Depending on local shop prices, you're probably paying $1500-$2000 to get the new gears installed? I wouldn't consider an $80 open carrier for the d30 to be a deal breaker...
And as mentioned, if you were even considering adding traction, now is the time. It'll save paying the same labor costs again. Doesn't even have to be thousand dollar selectables, the Detroit Truetrac is a great option for many of us.
You might even keep an eye on craigslist to see if you can find a take-off front d44 from a rubicon.
Old May 7, 2016 | 03:51 AM
I agree there was a guy on here that sold his factory LSD or like $150. It was under the drivetrain section.... I found it it was for the rear but people selling are out there.
https://www.jk-forum.com/forums/jk-a...u-trac-321297/
If your going to have it all apart try to at least upgrade a little.
Old May 7, 2016 | 08:09 AM
MICHAEL450f's Avatar
I'll sell you my sport axles with 3.73 for $1000. Just bolt them right up
