Broken Driveshaft
Old Oct 25, 2016 | 07:04 PM
gab24m3's Avatar
Default Broken Driveshaft
I have a Coast 1310 Driveshaft that broke from the u-joint and driveshaft yoke rear. Do I need to replace the whole driveshaft? I can only find the ujoint and cant seem to find the driveshaft yoke. Is there something I'm missing?
Old Oct 25, 2016 | 07:28 PM
TweakJK's Avatar
Can you post a picture? All parts are very readily available, they are all standard parts. Check out Dennys driveshaft.
Most driveshaft companies just buy spicer and neapco parts and put them together.
Old Oct 25, 2016 | 07:47 PM
gab24m3's Avatar
Not sure how good you can see that.
Old Oct 25, 2016 | 11:57 PM
DJ1's Avatar
DJ1
Former Member
I think you're gonna have to buy a whole new shaft unless Coast will allow you to mail that back in so they can install a new *sub-assembly that slips in and out and re-balance.....
Old Oct 26, 2016 | 01:59 AM
Chuck-The-Ripper's Avatar
While I'm sure they can fix it if you send it back, it wouldn't be very economical and it's not really needed. Any driveline shop should be able to grind the weld and attach a new ear on. It shouldn't be far off of around $75 or so..
Old Oct 26, 2016 | 04:55 AM
DJ1's Avatar
DJ1
Former Member
That makes sense also but I was figuring if you at least sent it back to the original mfg then I'd assume they'd reinstate a new warranty. For Coast I think it's 1 year.
Old Oct 26, 2016 | 04:58 AM
larry0071's Avatar
You have plenty of local shops that can toss it back together.
https://www.google.com/#q=El+Paso+Te...veshaft+repair
Old Oct 26, 2016 | 05:35 AM
gab24m3's Avatar
Thanks guys. I'll take it of today for repair then might as well upgrade to 1350. Christmas is around the corner so perfect excuse
Old Oct 26, 2016 | 06:56 AM
If you're looking to upgrade, I would recommend you considering having one built with the teraflex high angle rezeppas on each end. I for one, have had nothing but problems with my double cardan.
Old Oct 26, 2016 | 07:22 AM
Monte417's Avatar
I think there's a company that does that now. Can't remember who though. Twaton driveshafts or something
