3" stretch
Old Nov 9, 2016 | 05:59 PM
Wrangeler X's Avatar
I I'm seriously considering doing a 3" stretch. I have a 3.5 RK lift and would be upgrading the rear to the 3link long arm stretch. Looking for pics before and after and assessment of on road and Offroad improvement.
Old Nov 10, 2016 | 05:31 AM
TheDirtman's Avatar
A lot of work for minimal gain. I assume you are looking at a rear 3 link. Are you going to keep the rear shocks out back? If only doing 3" of stretch I would do the front as it will give you more performance gains then pushing the rear back.
Old Nov 10, 2016 | 07:06 AM
Invest2m4's Avatar
Agree with Dirtman. There was a thread on JKO not long ago that hashed it all out and as I recall, the obvious conclusion was not to do it.
Old Nov 10, 2016 | 04:34 PM
I though I read that but I don't recall finding an obvious conclusion of don't do it. Really struggling on this. The suspension isn't that bad. But when you add in corners and all four flares it's a big ticket!
I was going to 3" rear and hopefully get 1" in front.
Northridge 4x4
Old Nov 10, 2016 | 07:20 PM
TheDirtman's Avatar
You could simply stretch the front 3" and move the rear back 1" for a more simple and cheaper set up that will perform better with better approach angles. On the rear I would also cut off the lower arm mount and replace them with heavy duty ones that are higher up on the axle to give you more clearance and allow you to run the same length control arms if you want. Further saving you money on new lower arms. You would be able to retain the rear driveshaft but up front you will be looking at a longer shaft.
Old Nov 11, 2016 | 04:57 AM
kjeeper10's Avatar
Vet Army
Daystar is now offering a 3" stretch. They make it seem bolt on and ready to go.
Old Nov 11, 2016 | 08:16 AM
RiverCityOffroad's Avatar
Former Vendor
I started out with an off the shelf 3" stretch system and it evolved from there. It is now on a custom Rock Krawler Offroad Pro that is pushed 2" front and 4" rear. The thing works amazing offroad.
Is it a lot of work? Sure it is, but if you're researching this I assume you already realize this. Crawler Conceptz is making the corners to cover the stretch now which covers that headache that those of us before you had to work around.
https://www.jk-forum.com/forums/jk-g...-build-293351/
Marcus
Old Nov 11, 2016 | 08:18 AM
Former Vendor
Interesting! That looks like RK components.
Daystar? - Driven by Design
Old Nov 11, 2016 | 11:58 AM
kjeeper10's Avatar
Vet Army
Originally Posted by RiverCityOffroad
Interesting! That looks like RK components. Daystar? - Driven by Design
Yes sir !!!
Old Nov 12, 2016 | 02:26 AM
Just how do you stretch the front 3"? I like this idea but... looking at it, besides arms of course how do you deal with the steering linkage and shocks/springs?
Northridge 4x4
