Front Locker Light Flashing
Old Nov 13, 2016 | 05:54 AM
Punkineater's Avatar
Default Front Locker Light Flashing
Hi Guys,
Been on here for a while but don't post much. I'm from Utah and frequent Moab roughly 4 times a year. On my last trip down I bent the front axle housing in my Rubicon. Had the Dealer replace it with a Teraflex Tera44 housing and locked it in for the first time this weekend. When unlocking I can't get the front locker light to stop flashing. It seems to be disengaged but the light doesn't register this. Any thoughts?
Old Nov 13, 2016 | 04:00 PM
Joe_B's Avatar
My rear locker had the same issue and eventually stopped disengaging. It got annoying manually disengaging it after each weekend of wheeling. The issue is the sensor/plunger kept getting jammed. I pulled the plunger/sensor (in orange below) and plugged the hole in the housing. Locker works like a charm. When the locker is engaged the dash light will flash as if it's not engaged because the sensor is missing but that's not an issue. If you have a need to use lockers than you should know when they're engaged or not without the light telling you. The installer most likely messed up your sensor.
Old Nov 18, 2016 | 05:26 PM
Thanks for the reply. The Dealer replaced the plunger and no further issues.
