Superchips
I have a Superchips Flashcal for my 2015 JKU Rubicon to change tire size and gear ratio. What does the 4 high and 4 low transfer case gear ratio change do and what should I set them to with 35 inch tires and 4:56 gears. Thanks
High on the xfer case is 1:1, while low is 4:1.
The original axle gears in the rubi are 4:10s. You just want to update the ratio to 4:56 and adjust for the new wheel diameter.
