14/56 to 17/59 spring swap, spacer too?
Will be changing my 14/56 springs to a set of 17/59 I picked up. Seems from my reading I will gain 1 to 1.5 inches or so. My question is I was thinking of adding an additional 1/2" spacer in front to eliminate rake? Any thoughts if this should be fine. I already have the Rubicon shocks on.
Great, I just need to decide do I want a 1/2, 3/4 or 1" spacer in front then to get as close to level as I can. Not looking for addtional height beyond what I get from the springs just level.
Great, I just need to decide do I want a 1/2, 3/4 or 1" spacer in front then to get as close to level as I can. Not looking for addtional height beyond what I get from the springs just level. Am I reading right did you add 4 spacers to front and 2 in the rear?
You can also run this kit...https://www.amazon.com/EVO-1095-1-5-HD-Leveling-Kit/dp/B00TEA12UO/ref=sr_1_sc_1?s=automotive&ie=UTF8&qid=1525774911&sr=1-1-spell&keywords=evo+lefeling+kit
I am running those 2" coils from kit with 59 coils and 2" spacer in rear now. What size tires are you running or want to run?
