Jeep jk 2007 starter
Hi jeep won’t start but after 30 seconds all is fine
when i press the turn on key the starter make a noise i keep the key turned but the noise stops and the car doesn’t start
after 3-4-5 try the car start normally
the starter work and batteries is good
Turn on the ignition switch so that you can put it into neutral, push the jeep just a little. While its moving very slow move shifter to park, then try to start.. this will let you know if the flywheel may have a bad tooth.
