help me pick a lift kit.
Old Aug 23, 2008 | 06:34 AM
cinciredsfan77's Avatar
Default help me pick a lift kit.
alright I really want to lift my jeep to fit 35's later on but don't know which kit to buy. I want to get at least 3 inches of lift but i need to keep it under $800. I looked at the rough country 4in lift but i don't think that kit comes with all the parts you would need. I also thought about a teraflex 2.5 lift and adding 3/4 spacers on top but I am still lost in what i want. So if anyone could recommend a kit under $800 that gets at or around 3-4 inches of lift please help me out. thanks.
Old Aug 23, 2008 | 06:56 AM
wayoflife's Avatar
JK-Forum Founder
i have installed both kits and can tell you that they will do the job for you and well. if you go the rough country route, i would recommend that you get a set of adjustable front lower control arms so that you can dial in your caster but other than that, you should be fine and should be able to still do this for about $800. you should know though that if you have a 2-door, you will want to get a new rear u-joint style drive shaft along with adjustable rear upper control arms to dial in your pinion angle. also, if you have an automatic, you will want to replace your front drive shaft with a u-joint style unit as well. while it is not critical to do this right away, the steep angles on a 2-door rear shaft will compromise the CV boots in a real hury and up front, the spline shaft boot will tear off when it makes contact with your tranny.
Old Aug 23, 2008 | 07:00 AM
bly109's Avatar
Why not do a 2.5 BB like tera or RC and a 1" body lift? That will keep you in budget and also easily clear 35's. Heck, for 800, you probably could do one of the new Teraflex coil BBs, a 1" BL and still stay under 800
Old Aug 23, 2008 | 07:10 AM
Well i never thought about a body lift. Also i have never installed anything on any vehicle. So would i be able to install a lift kit or body lift by myself with a friend or two or would i be better off paying the money to get them installed professionally?
Alright so this BB would be fine right...
http://www.quadratec.com/products/16190_0005.htm
also what body lift would you recommend.
Old Aug 23, 2008 | 07:12 AM
wayoflife's Avatar
JK-Forum Founder
you can easily install both and by yourself in just a few hours and with basic tools. here are two write-ups that i did and should help you out:
http://project-jk.com/jeep-jk-write-...ation-write-up
going this route is very affordable and one that i would highly recommend
Old Aug 23, 2008 | 07:21 AM
Wow thanks for the help. I think that is exactly what i am going to do. Now i just have to convince the parents to let me buy them... By the way great write ups i will definitely use those if i do buy the items you suggested. thanks again!!
Old Aug 23, 2008 | 07:26 AM
bly109's Avatar
Definitely install them yourself! WOL's write-ups are extremely helpful and will get you through the installs without a hitch. Plus, if you would get stuck, you can always post your questions here and Im sure someone will have the answer for you fairly quickly. And just think of the cash you'll save and all the valuable knowledge you'll gain about your JK You never know when a break can occur on the trail. By installing your own lift, you will be more prepared to do a field repair.
And yes the Tera BB with shock extensions is a great lift, I ran it for about 10K without any problems.
As far as BL's go, most people seem to use either MORE or Performance Accessaries. I dont have one yet, but I'll most like go with one of those two.
Old Aug 23, 2008 | 07:27 AM
Mark Doiron's Avatar
I've installed the RC 2.5" lift on my JK and it went quite easily (by myself). I helped Torn and RescueX install a 1" BL on RescueX's JK (which already had a 2.5" lift) so that he could clear 35s. It was more a social event than that three of us were required. The one piece of advice I'd give is to soak the main bolts that hold the body in place with WD-40 the night before you do the job. We had a couple "toughies", and I've read where others did, too. After you pull the old bolts, ensure that you've cleaned out the threads before installing the new ones. Here's some pic's of RescueX's with a 2.5" BB and 1" BL on 35s I shot at the JK-Forum Disney run:
Old Aug 23, 2008 | 07:30 AM
bly109's Avatar
Hey Mark, Which tube fenders does he have? Thanks
Old Aug 23, 2008 | 07:35 AM
bly109's Avatar
And check out Northridge4x4, they are actually cheaper on that lift and its free shipping
http://www.northridge4x4.com/proddet...d=TF-001355210
