Warn winch brake durm
Old Sep 23, 2008 | 04:44 AM
Hammerman's Avatar
Default Warn winch brake durm
Has anyone had a brake problem with the Warn winch power plant hp. Once I ingage the winch lever in ingage mode I can still pull the rope out. My understanding is that once it is tighten( ingaged) you shouldn't be able to pull the rope out. yet when comming out of a store here mine is laying out about 10 feet.
Old Sep 23, 2008 | 05:22 AM
wayoflife's Avatar
JK-Forum Founder
if you are refering to the lever on the driver side and NOT the switch on the front, when it is locked into the spool position, no, you should not be able to pull the line out. if it is still free spooling, try to make sure that the lever is fully engaged (should be parallel to the lenght of your jeep) and try it again.
Old Sep 23, 2008 | 08:31 AM
Hammerman's Avatar
Default warn winch
Spoke with a warn Rep, they suggested I remove the spool and if its damage bad enough it will fall off or out, I'' try this several times.
Thanks for the reply
