Full Traction 3" + 35's - JK Rubi Issues!
Just got my lift on today and the steering seems a bit iffy....
We have the FT 3" Premium Kit, SpiderTrax Wheel Spacers and 35X12.50X15 BFG MTR's on a JK Rubicon...
Has anyone else had these issues???
- Steering wheels seems loose
- ESP was an issues as well
I installed my Premium kit on Saturday and it drives GREAT once the steering wheel was centered and the front track bar was adjusted. I used WOL's write ups to adjust them both and had no problems.
Step #57 to recenter the wheel.
http://project-jk.com/jeep-jk-write-...3-economy-lift
All the write-ups are on project-jk.com
How much pressure are you running in your tires. I went from 40psi to 27psi which is about where mine should be. That also helped. Do the chalk test to see where you should be. (Run over a chalk line and keep letting air out until it copies across the whole tread pattern)
Keep me posted. Hope some of this helps out!
I installed an ultimate kit and 35's over the weekend, and I too have the "wander" and ESP issues despite trying once (read: shooting in the dark) to adjust the camber by pulling the front lowers out about 5/8" longer than stock. I basically have no idea what I'm doing in this department, so I've got an appointment on Thursday with a reputable 4x4 shop to have them check everything out before I hop in it on Monday to drive from SF to Tucson
All in all, it's driveable, but I would really like to dial things in to get the "better than stock" ride that everyone claims with the ultimate kit. I'll see what happens on Thursday and make sure I debrief to understand what they actually adjusted (since I left the uppers stock length going in).
