will a 2.5" fit 35's?
Old Oct 27, 2008 | 02:17 PM
cbrann05's Avatar
Default will a 2.5" fit 35's?
i want to lift my jk x 2 door and i dont want to change the way it drives or effect the mpg to terribly...i have in mind a budget boost 2.5" lift will that clear 35-12.50?...will that be alot, little,or no tire scrubbing
Old Oct 27, 2008 | 02:20 PM
lijeepguy's Avatar
it will fit , but will rub when flexing , and your mpg will change a pretty fair amount
Old Oct 27, 2008 | 03:24 PM
XJHammer's Avatar
Originally Posted by N2rock
Yes it will. You will get rubbing on the fenders when off road, but on road is fine. BUT- you will need wheels with smaller back spacing or use 1.25" spacers on your stock wheels.
Just wondering, about how much rubbing.... Could you tear off your fenders, or will it just make noise? Sometimes the term rubbing is used for every little thing.
I'm also looking at the same type of setup. Keeping the stock tires for everyday, and the 35's for wheeling trips.
Old Oct 27, 2008 | 08:16 PM
deepcreekjk's Avatar
Default 2.5 tf bb
I have the 2.5 tf bb and run 35 cooper stt's on 15x8 pro comp rock crawlers w/3.75 backspacing with no rub anytime including wheeling.I was expecting to rub on the front bumper stuffed and turned but just squeeks by.here are some pic's.Could'nt be happier.Click for slide show.http://s105.photobucket.com/albums/m...t=6d394153.pbw
Old Oct 28, 2008 | 12:59 AM
sn4cktime's Avatar
short answer = yes
Old Oct 28, 2008 | 01:35 AM
gt4660's Avatar
Originally Posted by sn4cktime
short answer = yes
His answer times 2... A ton of people on here are doing it. I am just doing the leveling kit and flat fenders and triming the pinch seam. and bam 35's fit
Old Oct 29, 2008 | 06:40 PM
XJHammer's Avatar
Only rubbed when full flex, and no it wasn't enough to tear off the fenders, just an annoying/loud sound as the tire's tread rubbed across the fender lip. Freaks you out the first time you hear it because it sounds like you're tearing the fender completely off. But once you hear it a few times you get used to it.
When I heard that in my XJ, it made me feel like i was really putting the suspension to work. As well as warming my heart...
Old Oct 29, 2008 | 07:35 PM
justinstoffregen's Avatar
Default yes
it will..................but there's more to it if you want to get technical
