front bumper cover.. HELP PLEASE!
Old Apr 6, 2007 | 12:16 PM
chris_386's Avatar
Default front bumper cover.. HELP PLEASE!
I figured I would post this in this section as well becuase most people have either changed their bumpers or removed it. I hit a small post and it pushed in the section to the right of the front bumper. How can i get inbehind that fron cover to push it back out.
Thanks,
Chris
Old Apr 6, 2007 | 12:30 PM
Rubidon's Avatar
Get up under there and you will see the plastic covering with the dent will un screw pretty easy. I would take it off and punch it from the back, it should reform to original shape. a little heat may help.....never done this but if I had to this is what I would try!
Old Apr 6, 2007 | 12:37 PM
SDJK's Avatar
Default Bumper plastic
You pretty much have to remove the whole bumper-the plastic won't come off with the tow hooks sticking up-and they are bolted with the bumper bolts. I removed the plastic to mount tow bar brackets and it does'nt look too bad.
Old Apr 6, 2007 | 12:59 PM
Piginajeep's Avatar
check the writeup section. I have a bumper removal thread..
its really easy to do..
https://www.jk-forum.com/forums/jk-write-ups-39/factory-bumper-removal-2714/
Old Apr 6, 2007 | 01:41 PM
chris_386's Avatar
I put a 2 hairdryers to the jeep bumper and once it got hot i just pressed the plastic around until it they popped out.... it came out pretty good.. Just need to find something out there that will remove those types of scratches but I don't expect to find to much.. Anyways scratches build character..
Thanks for the replys. here she is now..
