Best Gears
Old Jan 6, 2009 | 01:05 AM
Mk-Dubai's Avatar
Default Best Gears
Im planning on getting my hands on some new gears...
Any ideas about who has the best
Old Jan 6, 2009 | 05:14 AM
tgrt's Avatar
Former Vendor
Doesn't really matter. They all ultimately come from the same manufacturer in China or India (I forget which). Superior, Precision, et al. are all the same.
Old Jan 6, 2009 | 05:40 AM
SLeepY_BoY's Avatar
i have superior...
Old Jan 6, 2009 | 05:58 AM
Piginajeep's Avatar
yup,
Richmond gears are made in the US. But I dont believe they make JK gears
Old Jan 6, 2009 | 06:32 AM
wayoflife's Avatar
JK-Forum Founder
FWIW, it's india
Old Jan 6, 2009 | 07:55 AM
jkkat's Avatar
<-- Has Yukons
Old Jan 6, 2009 | 02:51 PM
HaoleRubicon07's Avatar
i got superior 5.13's....love em.
Old Jan 6, 2009 | 05:26 PM
AZJeeper's Avatar
Community Favorite
Posted this a while back:
https://www.jk-forum.com/forums/modified-jk-tech-2/gears-options-except-superior-52833/
I did a little research trying to hunt down who makes what and where it's really made. Talked to Chad at Randy's Ring and Pinion, searched the web business directory, and cross-referenced part numbers. Here's what I found:
Randy's Ring and Pinion is also known as Ring and Pinion, Inc. The business is classified as Automotive Repair Shop and has 120 employees in three locations.
Randy's owns brands:
USA Standard Gear
Value Gear
Yukon Dura Lock
Yukon Gear & Axle
According to Chad, Randy's gets their Dana 44 gears from Superior Axle and Gear. These are branded as USA Standard Gear or if you want a prettier box Yukon Axle.
Superior Axle and Gear is also known as Foote Axle and Forge L.L.C., is classified as Motor Vehicle Parts and Accessories and has a total of 46 people. Their web site states "We are a 100% in-house manufacturer. We forge, CNC machine, heat treat, precision grind and spline right here in our Los Angeles facility."
Therefore USA Standard Gear = Yukon = Superior = Foote Axle and Forge = made in the USA -- At least for the Dana 44 gear set.
Couldn't find much on Alloy USA, LLC except that the business is classified as Auto and Home Supply Stores with a total of 6 people. Obviously they don't make their own gears.
Old Mar 10, 2009 | 04:20 PM
Strong Bad's Avatar
https://www.jk-forum.com/forums/showthread.php?t=52833
USA Standard Gear
Value Gear
Yukon Dura Lock
Yukon Gear & Axle
Very interesting info. I would be curious to see what the price difference is based on which label is on the box.
Old Mar 10, 2009 | 04:45 PM
Northridge4x4's Avatar
Sponsoring Vendor
USA Standard Gear
Value Gear
Yukon Dura Lock
Yukon Gear & Axle
This was true at the beginning now the yukon gears are a different MFG that we have been using for years and we have had great luck with.
David
