New Drive Shaft
i want to put the TeraFlex 3" lift on my JK. what i do not know is what kind of drive shaft do i need to buy for the front. i'm an idiot about this. i have no idea what i need.
I recently installed a rear JE Reel 1350!
Check these out.
https://www.jk-forum.com/forums/jk-write-ups-39/installing-je-reel-1350-rear-driveshaft-28160/
https://www.jk-forum.com/forums/show...ht=drive+shaft
I think you don't need to hurry up to replace drive shaft with 3rd party one.
Once you have seen leaking grease around CV joint (transfer side) and also
damaged boots (due to interference with tranny) then its signal to check new
one.
At the moment, nothing seems superior than OE part for drive shaft, my opinion.
I think hub conversion is more valuable than to replace drive shaft.
one.
one.
one.
There's also Tatton driveshafts. I have a freind who just installed one ($235.00 deivered) and I'm quite impressed with it. Awesome quality and great price/warranty. Check them out on Ebay.
Added Rubicon Express front driveshaft with 3" Full Flex Teraflex lift kit.
Problems.......vibrates. Took off and no vibration.
Sent out to be re-balanced, still vibrates.
May buy Teraflex driveshaft and see what happens.
Did you check your pinion angle and caster? Aftermarket driveshafts have different requirements than the stock POS.
one.
one.
The OE driveshaft was designed to give the Commander and Grand Cherokee a smooth ride. It should never have been put inthe JK. It was not designed to live with aftermarket lifts and control arms with flex joints that provide more articulation.
Why would a hub conversion be so valuable? What is he great benefit to justify the cost; which is not insignificant. I've seen enough failed stock JK drieveshafts to know it is a weak link and should be replaced.
