Any 2dr jeeps with 3" lift and factory drive shaft..?
the new JK has about 1000 miles on it.
If you have an auto, you'll need to replace both. If you have a standard. You can get away with just the rear.
JE reels are about $379 from 4wd hardware for the rears.
http://www.4wd.com/search.aspx?SH=QT...&AnswerID=1953
You will need the front for sure. When your front axle drops its going to hit the tranny skid.
