TF 4" Long Arm and Steering
Old Feb 2, 2009 | 03:58 PM
skeptic's Avatar
Default TF 4" Long Arm and Steering
Anyone have issues with steering/bump steer with this kit? TF sells a high steer/flip kit thats just shy of 400 bucks. Can I just by a drop pitman and track bar drop bracket? If so, who sells a good one. Would prefer bolt on as I'll likely go with a high steer/flip in the future. Or, can I just say F it and drive it w/o for a while.
Old Feb 2, 2009 | 04:03 PM
wayoflife's Avatar
JK-Forum Founder
i know that toad is running the TF track bar drop bracket w/brace and a dropped pitman arm. this is a good setup and does not require reaming out the steering knuckle. also, it will retain the factory geometry the best.
Old Feb 2, 2009 | 04:08 PM
skeptic's Avatar
So the bracket that comes with the TF kit does, in fact, drop the track bar. All I need to do is buy a 100 buck drop pitman...done
Old Feb 2, 2009 | 04:10 PM
wayoflife's Avatar
JK-Forum Founder
yes. it drops the track bar from the frame and it has a brace that gets welded to the opposite side. a great design and very beefy - you won't be seeing any flexing or breaking of the factory mount with this. as for the dropped pitman arm, yup, that's all you need and you're done. i run a similar setup and i'm very happy with how my jeep handles.
Old Feb 2, 2009 | 04:14 PM
skeptic's Avatar
nice. Thank you.
Old Feb 2, 2009 | 06:42 PM
JackMac4's Avatar
I went with the drag link flip and trackbar drop bracket with frame brace. It is real nice, but more expensive than the drop pitman arm and regular drop bracket.
You'll need one of them though, no doubt - you'll get bumpsteer with the 4" lift. I had it pretty bad on my 2dr. The drag link flip/trackbar lowering totally fixed it though - and is real solid.
