Arb front bumper without Winch
Old Mar 4, 2009 | 05:08 AM
tlpru's Avatar
Default Arb front bumper without Winch
did you buy the close out panel (used when you dont have a winch)?
or did you fabricate your own?..
i have heard that the arb close out panel is being designed?
thanks
trent
Old Mar 9, 2009 | 09:57 AM
tlpru's Avatar
anybody? any ideas?
Old Mar 9, 2009 | 10:08 AM
dadgummit's Avatar
It would be really easy to fab your own,
Just take some 3/4" x 3/4" x 3" pieces of wood (Lowes) and attach them to the vertical mounting points (the part of the metal bumper on the top where the sheet metal is bent dowm for the opening for the winch. There are holes on the left and right side. this is where a close out pannel would mount )
Once that wood is in all you need is a piece of metal (I like diamond plate aluminum) cut to the right size (any local metal shop with a shear machine should be able to do it for you)
Drill 2 holes in the right and left side of your new piece of metal for screws (making sure the holes line up with the wood so the screws can thread into the wood)
Good to go. Should cost like 20-30 dollars.
Old Mar 9, 2009 | 10:10 AM
dadgummit's Avatar
Or you can just get a cheap winch to fill the hole. These bumpers look pretty bad with no winch.
Old Mar 9, 2009 | 12:00 PM
davidmech21's Avatar
I made my own out of diamond plate.
This pic was taken when I first installed the bumper. I have since painted the diamond plate with duplicolor bedliner spray to match the bumper, and I've installed a license plate to cover the fairlead opening.
Old Mar 9, 2009 | 12:05 PM
bmcqueen's Avatar
I bought the filler panel
Old Mar 9, 2009 | 01:50 PM
dadgummit's Avatar
Nice, that is exactly what I was thinking about. I also like that you got rid of thise ugly rectangle amber lights!!
Old Mar 11, 2009 | 05:37 AM
tlpru's Avatar
where did you get the filler plate?...
Old Mar 11, 2009 | 07:03 AM
dadgummit's Avatar
Call Dave @ Northridge, he should be able to source it and have it drop shipped right away.
Old Mar 11, 2009 | 02:41 PM
kntr's Avatar
ARB makes a cover or you can make your own. I had one made and it looks great.
