Will 4.56 run in a D30 and D44?
I want to install 4.56 gearing b/c I'm running close to 35's. Regardless, I have a couple questions....
1.) Will 4.56 fit and run alright in a front D30 and a rear D44?
2.) Should I get Superior?
Thanks!
Thanks!
HAHAHA! I just got your message WOL.
Thank you for the help. Superior it is.
With 4.56 and running close to 35's, what should expect? -- more torque and less MPG, or roughly factory MPG, bad torque but good MPG?
honestly, i personally would recommend getting 4.88's if you're going to be running a 35" tire or close to it. that will give you close to factory performance. also, other makes you can check out are randy's ring and pinion, yukon and genuine.
You will need a new carrier for the 30, but beyond that, your golden. IMHO 4.56 is probably a little big for 35's, you might want to think about 4.88's or even 5.13's.
