Towing ?
Old Jun 30, 2009 | 01:38 AM
wspd440's Avatar
Default Towing ?
I have an 07 2-door rubicon w/6 speed transmission. I am thinking about buying a pop up camper to take camping. the camper i am looking at has an unloaded weight of 2545lbs. has anyone pulled anything this heavy and how did the jeep do
Old Jun 30, 2009 | 02:29 AM
meljr's Avatar
That is way over the rating -- especially for a two door, in my opinion. With my 4 door, I've towed in excess of 5,000 lbs of firewood for several hundred miles without any issues and even a farm tractor on an equipment trailer for less than 50 miles, but I wouldn't recommend it. By the way, all my trailers have good braking systems and some have weight distribution setups.
-meljr
Old Jun 30, 2009 | 03:56 AM
wspd440's Avatar
The unlimited shows to be rated for 3500lbs. the wrangler for 2000lbs. you said you pulled 5k with the unlimited that is 1500 over the rating so my 545 lbs over is not so bad. I may be wrong but that is what is on jeep.com when you look it up. my owners manual says 2500lbs. i have seen people pulling some heavy stuff that was clearly over the load rating.
Old Jun 30, 2009 | 05:26 AM
ronjenx's Avatar
I didn't see 2500lbs in any of the manuals for the 2dr.
Don't justify what you want to do based on what others have done and gotten away with. That won't help you when something goes wrong and someone gets hurt. When the investigation reveals you were overloaded, you will become the responsible party. The 2dr is probably less tolerant of exceeding the tow limit.
Old Jun 30, 2009 | 05:33 AM
meljr's Avatar
Oh, I agree with what you say. I guess my largest concern with the 2 door would be the shorter wheelbase and having to stop quick. I actually trailer quite a bit, but I have several built tow rigs (Dodge trucks - Power Wagons and Cummins diesels rule) for most of the heavy hauling.
In thousands of miles of pulling a trailer, I've only had one accident where I couldn't quite stop when some uninsured drunk asshole decided to turn the wrong way on a one way street right in front of me. Even then, I only hit him at walking speed and the damage was minimal. Does your trailer have brakes? I would suggest getting a brake controller for the JK -- very handy for keeping things under control downhill also.
-meljr
Old Jun 30, 2009 | 08:57 AM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
that depends of you have the tow package if you are even rated to tow 2000, if you have the 3.21 gears and no tow package you are only rated to tow 1000, look at the towing capacity link
Old Jun 30, 2009 | 09:07 AM
tkob1060's Avatar
Trailer Towing Weights (Maximum Trailer Weight Ratings)
The following chart provides the maximum trailer weight ratings towable for your given drivetrain.
Engine/
Transmission
Axle Model GCWR (Gross
Combined Wt. Rating)
Frontal Area Max. GTW
(Gross Trailer
Wt.)
Max. Tongue
Wt. (See Note
1)
3.8L/
Manual
3.21 2 Door X
Model
(4WD)
4,910 lbs (2 227 kg) 25 sq. ft. (2.32
square meters)
1,000 lbs (453 kg) 100 lbs (45 kg)
3.8L/
Manual
4.10 2 Door X
Model
(4WD)
square meters)
2,000 lbs (907 kg) 200 lbs (91 kg)
3.8L/
Automatic
4.10 2 Door X
Model
(4WD)
5,935 lbs (2 692 kg) 25 sq. ft. (2.32
square meters)
3.8L/
Manual
3.21 2 Door
Sahara
Model
(4WD)
5,101 lbs (2 314 kg) 25 sq. ft. (2.32
square meters)
so where did you see 2500?
why do so many people on here question the tow rating and then try to convince others that it will be safe to tow over the rating
if you really want to tow something higher then the rated weight then go ahead but its not going to be safe and YOU will be responsible if you cause injuries or worse in an accident. Will you feel better if people tell you its ok and you do cause an accident?
Old Jun 30, 2009 | 06:35 PM
TxCop07's Avatar
Vet Army
find an aluminum pop up camper they are very light
Old Jun 30, 2009 | 06:38 PM
TxCop07's Avatar
Vet Army
Quicksilver 8.0
fully loaded, it's 1500lbs
as it sits, about 900lbs
Old Jun 30, 2009 | 07:01 PM
wspd440's Avatar
I stand corrected. it has been more than a year since reading the owners manual after digging it out tonight i do see that the max gtw is 2k.
