Camber ?
Old May 31, 2007 | 04:31 AM
GRSuspension's Avatar
Default Camber ?
Hi
we put a 4" lift, without adjustable arm. Someone have ever see a camber effect on the driver side wheel after an lift kit installation ?
thanks
Old May 31, 2007 | 06:35 AM
BLKRUBI's Avatar
I have a 4" lift without adjustable arms, but I'm not sure what you are asking.
Old May 31, 2007 | 06:40 AM
wayoflife's Avatar
JK-Forum Founder
Camber is an alignment issue that needs to be dealt with of IFS vehicles only. The Jeep JK Wrangler has a soild front axle and therefore a lift will not and cannot effect or change your camber.
Old May 31, 2007 | 06:54 AM
gjeepguy's Avatar
adjustable arms are required to change castor, not camber... the only way your wheel could be off is if there is something between the mounting surface and the wheel or your lugnuts arent tight.
Old May 31, 2007 | 08:03 AM
i know, but when i'm in front of the jeep, it look like have camber problem.
A solid axle can have also camber, if the axle was rotated (caster), because the angle between the upper and lower ball joint.
Old May 31, 2007 | 08:06 AM
CLACKEY(_!_)'s Avatar
Old May 31, 2007 | 08:31 AM
i lost the hosting on my.project.....the pic was there.
thanks for the help.
