California Vehicle Code Violations
Old 09-15-2009, 01:58 PM
SGT.'s Avatar
Default California Vehicle Code Violations
Mechanical Violations: Fix it ticket type Stuff:
I keep getting these kinds of questions and I keep seeing a lot of people giving REALLY bad or false information: so here are some of the common mechanical vehicle code violations:
Also if you have any other questions in regards to something PM me or post it and I will answer the best I can and back it up with the CVC. I will also then try to add it to this thread.
Thank You.
Fenders / Mud Flap Violations
27600. No person shall operate any motor vehicle having three or
more wheels, any trailer, or semitrailer unless equipped with
fenders, covers, or devices, including flaps or splash aprons, or
unless the body of the vehicle or attachments thereto afford adequate
protection to effectively minimize the spray or splash of water or
mud to the rear of the vehicle and all such equipment or such body or
attachments thereto shall be at least as wide as the tire tread.
This section does not apply to those vehicles exempt from
registration, trailers and semitrailers having an unladen weight of
under 1,500 pounds, or any vehicles manufactured and first registered
prior to January 1, 1971, having an unladen weight of under 1,500
pounds.
Fenders must cover the tire and generally the mud flap / splash guard will hang about an inch or two below the center of the axle , thats why why stock cars such as hondas toyotas have them and stock toyotas trucks have them off the lot as standard equipment.
Modification of Exhaust Systems
27151. (a) No person shall modify the exhaust system of a motor vehicle in a manner which will amplify or increase the noise emitted by the motor of the vehicle so that the vehicle is not in compliance with the provisions of Section 27150 or exceeds the noise limits established for the type of vehicle in Article 2.5 (commencing with Section 27200). No person shall operate a motor vehicle with an exhaust system so modified.
(b) For the purposes of exhaust systems installed on motor vehicles with a manufacturer's gross vehicle weight rating of less than 6,000 pounds, other than motorcycles, a sound level of 95 dbA or less, when tested in accordance with Society of Automotive Engineers Standard J1169 May 1998, complies with this section. Motor vehicle exhaust systems or parts thereof include, but are not limited to, nonoriginal exhaust equipment.
Exhaust Pipes
27152. The exhaust gases from a motor vehicle shall not be directed to the side of the vehicle between 2 feet and 11 feet above the ground.
Transparent Materials (Tinted Windows)
26708.5. (a) No person shall place, install, affix, or apply any transparent material upon the windshield, or side or rear windows, of any motor vehicle if the material alters the color or reduces the light transmittance of the windshield or side or rear windows, except as provided in subdivision (b), (c), or (d) of Section 26708.
(b) Tinted safety glass may be installed in a vehicle if (1) the glass complies with motor vehicle safety standards of the United States Department of Transportation for safety glazing materials, and (2) the glass is installed in a location permitted by those standards for the particular type of glass used.
Foglamps
24403. (a) A motor vehicle may be equipped with not more than two foglamps that may be used with, but may not be used in substitution of, headlamps.
(b) On a motor vehicle other than a motorcycle, the foglamps authorized under this section shall be mounted on the front at a height of not less than 12 inches nor more than 30 inches and aimed so that when the vehicle is not loaded none of the high-intensity portion of the light to the left of the center of the vehicle projects higher than a level of four inches below the level of the center of the lamp from which it comes, for a distance of 25 feet in front of the vehicle.
(c) On a motorcycle, the foglamps authorized under this section shall be mounted on the front at a height of not less than 12 inches nor more than 40 inches and aimed so that when the vehicle is not loaded none of the high-intensity portion of the light to the left of the center of the vehicle projects higher than a level of four inches below the level of the center of the lamp from which it comes, for a distance of 25 feet in front of the vehicle.
Auxiliary Lamps: Off-Highway Use
24411. Notwithstanding any other provision of law, a vehicle may be equipped with not more than eight lamps for use as headlamps while the vehicle is operated or driven off the highway. The lamps shall be mounted at a height of not less than 16 inches from the ground, or more than 12 inches above the top of the passenger compartment, at any place between the front of the vehicle and a line lying on a point 40 inches to the rear of the seat occupied by the driver, shall be wired independently of all other lighting circuits, and, whenever the vehicle is operated or driven upon a highway, shall be covered or hooded with an opaque hood or cover, and turned off.
Spot Lamps
24404. (a) A motor vehicle may be equipped with not to exceed two white spotlamps, which shall not be used in substitution of headlamps.
(b) No spotlamp shall be equipped with any lamp source exceeding 32 standard candlepower or 30 watts nor project any glaring light into the eyes of an approaching driver.
(c) Every spotlamp shall be so directed when in use:
That no portion of the main substantially parallel beam of light will strike the roadway to the left of the prolongation of the left side line of the vehicle.
That the top of the beam will not strike the roadway at a distance in excess of 300 feet from the vehicle.
(d) This section does not apply to spotlamps on authorized emergency vehicles.
(e) No spotlamp when in use shall be directed so as to illuminate any other moving vehicle.
Headlamps on Motor Vehicles
24400. (a) A motor vehicle, other than a motorcycle, shall be:
(1) Equipped with at least two headlamps, with at least one on each side of the front of the vehicle, and, except as to vehicles registered prior to January 1, 1930, they shall be located directly above or in advance of the front axle of the vehicle. The headlamps and every light source in any headlamp unit shall be located at a height of not more than 54 inches nor less than 22 inches.
(2) Operated during darkness, or inclement weather, or both, with at least two lighted headlamps that comply with paragraph (1).
(b) As used in paragraph (2) of subdivision (a), “inclement weather” is a weather condition that is either of the following:
(1) A condition that prevents a driver of a motor vehicle from clearly discerning a person or another motor vehicle on the highway from a distance of 1,000 feet.
(2) A condition requiring the windshield wipers to be in continuous use due to rain, mist, snow, fog, or other precipitation or atmospheric moisture.
Display of License Plates
5200. (a) When two license plates are issued by the department for use upon a vehicle, they shall be attached to the vehicle for which they were issued, one in the front and the other in the rear.
(b) When only one license plate is issued for use upon a vehicle, it shall be attached to the rear thereof , unless the license plate is issued for use upon a truck tractor, in which case the license plate shall be displayed in accordance with Section 4850.5. Amended Sec. 27, Ch. 594, Stats. 2003. Effective January 1, 2004.
Frame and Floor Height
24008.5. (a) No person shall operate any motor vehicle with a frame height or body floor height greater than specified in subdivisions (b) and (c).
(b) The maximum frame height is as follows:
[This table lists the maximum frame height for various types of vehicles.] * Vehicle Type Frame Height
(1) Passenger vehicles, except housecars 23 inches
(2) All other motor vehicles, including housecars, as follows:
Up to 4,500 pounds GVWR 27 inches
4,501 to 7,500 pounds GVWR 30 inches
7,501 to 10,000 pounds GVWR 31 inches
(c) The lowest portion of the body floor shall not be more than five inches above the top of the frame.
(d) The following definitions govern the construction of this section:
(1) "Frame" means the main longitudinal structural members of the chassis of the vehicle or, for vehicles with unitized body construction, the lowest main longitudinal structural members of the body of the vehicle.
(2) "Frame height" means the vertical distance between the ground and the lowest point on the frame, measured when the vehicle is unladen on a level surface at the lowest point on the frame midway between the front axle and the second axle on the vehicle.
(3) "GVWR" means the manufacturer's gross vehicle weight rating, as defined in Section 390, whether or not the vehicle is modified by use of parts not originally installed by the manufacturer.
• The bracketed information has been added editorially to meet accessibility requirements and is not part of statute.
Front Bumper
35408. In no event shall a front bumper on a motor vehicle be constructed or installed so as to project more than two feet forward of the foremost part of either the fenders or cab structure or radiator, whichever extends farthest toward the front of such vehicle.
Loads
35406. (a) Except as provided in subdivision (b), the load upon any vehicle operated alone, or the load upon the front vehicle of a combination of vehicles, shall not extend more than three feet beyond the foremost part of the front tires of the vehicle or the front bumper of the vehicle, if it is equipped with a front bumper.
(b) When the load is composed solely of vehicles, the load upon the front vehicle of a combination of vehicles shall not extend more than four feet beyond the foremost part of the front tires of the vehicle or the front bumper of the vehicle, if it is equipped with a front bumper.
Mirrors
26709. (a) Every motor vehicle registered in a foreign jurisdiction and every motorcycle subject to registration in this state shall be equipped with a mirror so located as to reflect to the driver a view of the highway for a distance of at least 200 feet to the rear of such vehicle.
Every motor vehicle subject to registration in this state, except a motorcycle, shall be equipped with not less than two such mirrors, including one affixed to the left-hand side.
(b) The following described types of motor vehicles, of a type subject to registration, shall be equipped with mirrors on both the left-and right-hand sides of the vehicle so located as to reflect to the driver a view of the highway through each mirror for a distance of at least 200 feet to the rear of such vehicle:
(1) A motor vehicle so constructed or loaded as to obstruct the driver's view to the rear.
(2) A motor vehicle towing a vehicle and the towed vehicle or load thereon obstructs the driver's view to the rear.
(3) A bus or trolley coach.
(c) The provisions of subdivision (b) shall not apply to a passenger vehicle when the load obstructing the driver's view consists of passengers.
Windshields: Exception
26700. (a) Except as provided in subdivision (b), a passenger vehicle, other than a motorcycle, and every bus, motortruck or truck tractor, and every firetruck, fire engine or other fire apparatus, whether publicly or privately owned, shall be equipped with an adequate windshield.
(b) Subdivision (a) does not apply to any vehicle issued identification plates pursuant to Section 5004 which was not required to be equipped with a windshield at the time it was first sold or registered under the laws of this state, another state, or foreign jurisdiction.
Amended Ch. 222, Stats. 1983. Effective January 1, 1984.
Windshield Exemption
36515. The provisions of Section 26700 relating to windshields shall not apply to implements of husbandry.
Added Ch. 2149, Stats. 1963. Effective September 20, 1963.
Windshield Wipers
26706. (a) Every motor vehicle, except motorcycles, equipped with a windshield shall also be equipped with a self-operating windshield wiper.
(b) Every new motor vehicle first registered after December 31, 1949, except motorcycles, shall be equipped with two such windshield wipers, one mounted on the right half and one on the left half of the windshield, except that any motor vehicle may be equipped with a single wiper so long as it meets the wiped area requirements in Federal Motor Vehicle Safety Standards Governing Windshield Wiping and Washing Systems.
(c) This section does not apply to snow removal equipment equipped with adequate manually operated windshield wipers.
Amended Ch. 196, Stats. 1978. Effective January 1, 1979.
Condition and Use of Windshield Wipers
26707. Windshield wipers required by this code shall be maintained in good operating condition and shall provide clear vision through the windshield for the driver. Wipers shall be operated under conditions of fog, snow, or rain and shall be capable of effectively clearing the windshield under all ordinary storm or load conditions while the vehicle is in operation.
Tread Depth of Pneumatic Tires
27465. (a) No dealer or person holding a retail seller's permit shall sell, offer for sale, expose for sale, or install on a vehicle axle for use on a highway, a pneumatic tire when the tire has less than the tread depth specified in subdivision (b). This subdivision does not apply to any person who installs on a vehicle, as part of an emergency service rendered to a disabled vehicle upon a highway, a spare tire with which the disabled vehicle was equipped.
(b) No person shall use on a highway a pneumatic tire on a vehicle axle when the tire has less than the following tread depth, except when temporarily installed on a disabled vehicle as specified in subdivision (a):
(1) One thirty-second (1/32) of an inch tread depth in any two adjacent grooves at any location of the tire, except as provided in paragraphs (2) and (3).
(2) Four thirty-second (4/32) of an inch tread depth at all points in all major grooves on a tire on the steering axle of any motor vehicle specified in Section 34500, and two thirty-second of an inch tread depth at all points in all major grooves on all other tires on the axles of these vehicles.
(3) Six thirty-second (6/32) of an inch tread depth at all points in all major grooves on snow tires used in lieu of tire traction devices in posted traction device control areas.
(c) The measurement of tread depth shall not be made where tie bars, humps, or fillets are located.
(d) The requirements of this section shall not apply to implements of husbandry.
(e) The department, if it determines that such action is appropriate and in keeping with reasonable safety requirements, may adopt regulations establishing more stringent tread depth requirements than those specified in this section for those vehicles defined in Sections 322 and 545, and may adopt regulations establishing tread depth requirements different from those specified in this section for those vehicles listed in Section 34500.
Amended Ch. 71, Stats. 1990. Effective May 1, 1990.
(For all the people changing lights, tinting the light housing, taillights, side markers, reflectors, fender trims, etc.)
Modification of Vehicle Equipment
26101. No person shall sell or offer for sale for use upon or as part of the equipment of a vehicle, nor shall any person use upon a vehicle, any device that is intended to modify the original design or performance of any lighting equipment, safety glazing material, or other device, unless the modifying device meets the provisions of Section 26104. This section does not apply to a taillamp or stop lamp in use on or prior to December 1, 1935, or to lamps installed on authorized emergency vehicles.
26104. (a) Every manufacturer who sells, offers for sale, or
manufactures for use upon a vehicle devices subject to requirements established by the department shall, before the device is offered for sale, have laboratory test data showing compliance with such requirements. Tests may be conducted by the manufacturer.
(b) The department may at any time request from the manufacturer a copy of the test data showing proof of compliance of any device with the requirements established by the department and additional evidence that due care was exercised in maintaining compliance during production. If the manufacturer fails to provide such proof of compliance within 30 days of notice from the department, the
department may prohibit the sale of the device in this state until acceptable proof of compliance is received by the department.
Color of Lamps and Reflectors
25950. This section applies to the color of lamps and to any reflector exhibiting or reflecting perceptible light of 0.05 candela or more per foot-candle of incident illumination. Unless provided otherwise, the color of lamps and reflectors upon a vehicle shall be as follows:
(a) The emitted light from all lamps and the reflected light from all reflectors, visible from in front of a vehicle, shall be white or yellow, except as follows:
(1) Rear side marker lamps required by Section 25100 may show red to the front.
(2) The color of foglamps described in Section 24403 may be in the color spectrum from white to yellow.
(3) An illuminating device, as permitted under Section 24255, shall emit radiation predominantly in the infrared region of the electromagnetic spectrum. Any incidental visible light projecting to the front of the vehicle shall be predominantly yellow to white. Any incidental visible light projecting to the rear of the vehicle shall be predominantly red. Any incidental visible light from an illuminating device, as permitted under Section 24255, shall not resemble any other required or permitted lighting device or official traffic control device.
(b) The emitted light from all lamps and the reflected light from all reflectors, visible from the rear of a vehicle, shall be red except as follows:
(1) Stoplamps on vehicles manufactured before January 1, 1979, may show yellow to the rear.
(2) Turn signal lamps may show yellow to the rear.
(3) Front side marker lamps required by Section 25100 may show yellow to the rear.
(4) Backup lamps shall show white to the rear.
(5) The rearward facing portion of a front-mounted double-faced turn signal lamp may show amber to the rear while the headlamps or parking lamps are lighted, if the intensity of the light emitted is not greater than the parking lamps and the turn signal function is not impaired.
(6) A reflector meeting the requirements of and installed in accordance with Section 24611 shall be red or white, or both.
(c) All lamps and reflectors visible from the front, sides, or rear of a vehicle, except headlamps, may have any unlighted color, provided the emitted light from all lamps or reflected light from all reflectors complies with the required color. Except for backup lamps, the entire effective projected luminous area of lamps visible from the rear or mounted on the sides near the rear of a vehicle shall be covered by an inner lens of the required color when the unlighted color differs from the required emitted light color. Taillamps, stoplamps, and turn signal lamps that are visible to the rear may be white when unlighted on vehicles manufactured before January 1, 1974.
Amended Sec. 38, Ch. 766, Stats. 1995. Effective January 1, 1996.
Amended Sec. 4, Ch. 198, Stats. 2004. Effective January 1, 2005.
CONTINUED IN POST #6
Old 10-31-2009, 10:14 AM
gdeal's Avatar
Default CA Vehicle Code
This is really good stuff to know. Thank You Very Much.
George Deal
Wildomar USA
Old 11-24-2009, 04:25 PM
07crawler's Avatar
uh huh...wife just got a fix it for the license plate...but the car is in my name so guess who has to deal with it.....yeah ME.....I think the highway patrol has better things to do than that...oh well....off with my custom and back with the license plate
Old 11-24-2009, 06:23 PM
07crawler's Avatar
Yes I have the 2 plates, but I had a custom one on the front, my point is what the heck does it really matter if I don;t have one on the front?...you usually get pulled over from the back anyways NOT the front...lol...California..Iike it here but hate the laws
Old 12-08-2009, 08:57 AM
SGT.'s Avatar
CONTINUED FROM POST #1
Stoplamps
24603. Every motor vehicle which is not in combination with any other vehicle and every vehicle at the end of a combination of vehicles shall at all times be equipped with stoplamps mounted on the rear as follows:
(a) Every such vehicle shall be equipped with one or more stoplamps.
(b) Every such vehicle, other than a motorcycle, manufactured and first registered on or after January 1, 1958, shall be equipped with two stoplamps, except that trailers and semitrailers manufactured after July 23, 1973, which are less than 30 inches wide, may be equipped with one stoplamp which shall be mounted at or near the vertical centerline of the trailer. If such vehicle is equipped with two stoplamps, they shall be mounted as specified in subdivision (d).
(c) Except as provided in subdivision (h), stoplamps on vehicles manufactured on or after January 1, 1969, shall be mounted not lower than 15 inches nor higher than 72 inches, except that a tow truck, in addition to being equipped with the required stoplamps, may also be equipped with two stoplamps which may be mounted not lower than 15 inches nor higher than the maximum allowable vehicle height and as far forward as the rearmost portion of the driver's seat in the rearmost position.
(d) Where two stoplamps are required, at least one shall be mounted at the left and one at the right side, respectively, at the same level.
(e) Stoplamps on vehicles manufactured on or after January 1, 1979, shall emit a red light. Stoplamps on vehicles manufactured before January 1, 1979, shall emit a red or yellow light. All stoplamps shall be plainly visible and understandable from a distance of 300 feet to the rear both during normal sunlight and at nighttime, except that stoplamps on a vehicle of a size required to be equipped with clearance lamps shall be visible from a distance of 500 feet during such times.
(f) Stoplamps shall be activated upon application of the service (foot) brake and the hand control head for air, vacuum, or electric brakes. In addition, all stoplamps may be activated by a mechanical device designed to function only upon sudden release of the accelerator while the vehicle is in motion. Stoplamps on vehicles equipped with a manual transmission may be manually activated by a mechanical device when the vehicle is downshifted if the device is automatically rendered inoperative while the vehicle is accelerating.
(g) Any vehicle may be equipped with supplemental stoplamps mounted to the rear of the rearmost portion of the driver's seat in its rearmost position in addition to the lamps required to be mounted on the rear of the vehicle. Supplemental stoplamps installed after January 1, 1979, shall be red in color and mounted not lower than 15 inches above the roadway. The supplemental stoplamp on that side of a vehicle toward which a turn will be made may flash as part of the supplemental turn signal lamp.
A supplemental stoplamp may be mounted inside the rear window of a vehicle, if it is mounted at the centerline of the vehicle and is constructed and mounted so as to prevent any light, other than a monitorial indicator emitted from the device, either direct or reflected, from being visible to the driver.
(h) Any supplemental stoplamp installed after January 1, 1987, shall comply with Federal Motor Vehicle Safety Standard No. 108 (49 C.F.R. 571.108). Any vehicle equipped with a stoplamp which complies with the federal motor vehicle safety standards applicable to that make and model vehicle shall conform to that applicable safety standard unless modified to comply with the federal motor vehicle safety standard designated in this subdivision.
Amended Ch. 924, Stats. 1988. Effective January 1, 1989.
Backup Lamps
24606. (a) Every motor vehicle, other than a motorcycle, of a type subject to registration and manufactured on and after January 1, 1969, shall be equipped with one or more backup lamps either separately or in combination with another lamp. Any vehicle may be equipped with backup lamps.
(b) Backup lamps shall be so directed as to project a white light illuminating the highway to the rear of the vehicle for a distance not to exceed 75 feet. A backup lamp may project incidental red, amber, or white light through reflectors or lenses that are adjacent or close to, or a part of, the lamp assembly.
(c) Backup lamps shall not be lighted except when the vehicle is about to be or is backing or except in conjunction with a lighting system which activates the lights for a temporary period after the ignition system is turned off.
(d) Any motor vehicle may be equipped with a lamp emitting white light on each side near or on the rear of the vehicle which is designed to provide supplemental illumination in an area to the side and rear not lighted by the backup lamps. These lamps shall be lighted only with the backup lamps.
Amended Ch. 813, Stats. 1981. Effective January 1, 1982.
Taillamps
24600. During darkness every motor vehicle which is not in combination with any other vehicle and every vehicle at the end of a combination of vehicles shall be equipped with lighted taillamps mounted on the rear as follows:
(a) Every vehicle shall be equipped with one or more taillamps.
(b) Every vehicle, other than a motorcycle, manufactured and first registered on or after January 1, 1958, shall be equipped with not less than two taillamps, except that trailers and semitrailers manufactured after July 23, 1973, which are less than 30 inches wide, may be equipped with one taillamp which shall be mounted at or near the vertical centerline of the vehicles. If a vehicle is equipped with two taillamps, they shall be mounted as specified in subdivision (d).
(c) Every vehicle or vehicle at the end of a combination of vehicles, subject to subdivision (a) of Section 22406 shall be equipped with not less than two taillamps.
(d) When two taillamps are required, at least one shall be mounted at the left and one at the right side respectively at the same level.
(e) Taillamps shall be red in color and shall be plainly visible from all distances within 500 feet to the rear except that taillamps on vehicles manufactured after January 1, 1969, shall be plainly visible from all distances within 1,000 feet to the rear.
(f) Taillamps on vehicles manufactured on or after January 1, 1969, shall be mounted not lower than 15 inches nor higher than 72 inches, except that a tow truck, in addition to being equipped with the required taillamps, may also be equipped with two taillamps which may be mounted not lower than 15 inches nor higher than the maximum allowable vehicle height and as far forward as the rearmost portion of the driver's seat in the rearmost position. The additional taillamps on a tow truck shall be lighted whenever the headlamps are lighted.
Sound (Loud radio, even with the top down...)
27007. No driver of a vehicle shall operate, or permit the
operation of, any sound amplification system which can be heard
outside the vehicle from 50 or more feet when the vehicle is being
operated upon a highway, unless that system is being operated to
request assistance or warn of a hazardous situation.
This section does not apply to authorized emergency vehicles or
vehicles operated by gas, electric, communications, or water
utilities. This section does not apply to the sound systems of
vehicles used for advertising, or in parades, political or other
special events, except that the use of sound systems on those
vehicles may be prohibited by a local authority by ordinance or
resolution.
Old 12-08-2009, 09:03 AM
JK-Forum Founder
wayoflife's Avatar
this is a great thread SGT.!! thanks for posting it up
Old 12-16-2009, 11:15 AM
AlmightyCrash's Avatar
Awesome info.
Looks like I might need it.
Old 12-16-2009, 06:03 PM
Ok.
Looks like:
front stinger is out.
windows must be stripped.
new fenders must be at least as wide as my current bushwackers.
Exhaust needs to be re-replaced.
Snorkel may just be for show...though I do utilize the stock box.
Old 01-30-2010, 06:29 PM
Sgt Mack's Avatar
Good write up, You made it a lot easier to point out this things to guys driving around camp pendleton that are in violation.
Old 05-31-2010, 05:37 AM
KSARG1's Avatar
This is good stuff!
Quick Reply: California Vehicle Code Violations
