Differential Fluid Change Out
Old Jan 5, 2009 | 06:37 PM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by jk77
I will take you up on the help for sure. I don't have any tools, nor do I have a drain pan, nor do I have the knowledge on how to pull off the cover so I can clean this thing.
To all: Would anyone agree that I should remove the entire cover and clean with brake cleaner and replace the cover and refill with synthetic? What synthetic would you all recommend.
Thanks
well, it might not be necessary but it would allow you to do a more thorough cleaning. here is a link that would help you to do that:
http://project-jk.com/jeep-jk-write-...r-installation
and, if you need help with this, let me know as i'd be more than happy to help out as well. got all the tools necessary and can get you done in about a 1/2 hour
Old Jan 5, 2009 | 06:52 PM
Roxster's Avatar
Thanks
Just my 2 cents... since you're not dealing with heavy sludge, I'd consider draining the fluid and then cleaning it out without pulling the cover. Refill the diff with kerosene (an excellent cleaner) mixed with some cheap motor oil and drive around the block a few times (a couple miles). Drain this contaminated conconction and then fill with your new synthetic gear oil.
As for tools, all you'll need are a drain pan and 3/8" ratchet with short extension. You can squeeze the oil out of the bottles directly into the diff fill holes, though it takes a little time and effort to keep it neat and avoid spills. The drain pans can be had at Pep Boys, AutoZone, Wal-Mart, etc. for $10 or so. Get one of these to do the job, and one of us can bring along a few assorted hand tools if you don't have them readily available (if you don't, allocate some of your $400 savings for some tools! )..
I should be available tomorrow evening, or this weekend as an alternative. If you don't have it done by then, send me a PM and I'll plan to give you a hand.
I'm interested to know if any others here would differ on my suggestion on cleaning out the diff in the way I described. Thoughts?
Ron
Old Jan 5, 2009 | 06:56 PM
Roxster's Avatar
Originally Posted by serveapurpose
I'd recommend Royal Purple!
x2 on the Royal Purple.
Old Jan 5, 2009 | 07:18 PM
serveapurpose's Avatar
Sponsoring Vendor
Off Road Evolution Rep
Ron
x2 on the go and buy a drain pan, Royal Purple, and call us tommorow evening if you still need the help!
Old Jan 5, 2009 | 07:46 PM
UCLA JK Rida''s Avatar
Scotty:
Lucas is good stuff, too. I did Royal Purple at 15K and Lucas at 30K...similar performance and gear protection, and I think Lucas might be a buck or two cheaper than RP.
Russ D.
Old Jan 5, 2009 | 10:47 PM
Just a thought for you guys, concerning additives.
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Old Jan 5, 2009 | 10:59 PM
Yeah, good link, B. I NEVER put in additives to an already good oil (i.e. Mobil 1, Castrol Syntec, Royal Purple, et. al). It's a waste of money, as your link demonstrated, can potentially do more harm than good. Full synthetic doesn't necessitate anything extra.
Russ D.
Old Jan 7, 2009 | 07:36 PM
Sponsoring Vendor
JK77 did you get the problem fixed?
Old Jan 8, 2009 | 05:39 AM
jk77's Avatar
yes my jeep is good to go thanks
Old Jan 8, 2009 | 05:49 AM
Rhino64's Avatar
Ron
I used to use that method to flush my engine, works great.
