Lift install help?
Old May 29, 2010 | 11:41 AM
Diablo Blanco's Avatar
Originally Posted by GHes
I like the lift. I put it on by by myself about two months ago using the Project JK write up. The instructions are good but I have two comments to add to them.
Make sure you have tall jack stands. I ended up setting my stands onto some wood shelves to get another 2-3 inches of height in order to be able to drop the axle enough to install the new springs (after jacking the jeep up 2-3 times). The other thing to watch for is on the back end, pay attention to how the new rear springs set. I had everything installed and bolted down and when I lowered the jeep back onto the floor I realized that one of the springs was very close to the track bar and would likely rub. I have to disassemble the back end again, rotate the spring about 90 degrees and then bolt it all back together again.
Did you order adjustable track bars and new sway bar links? You will need those to correct the geometry. I have to confess that I'm still tweaking is the straightening of the steering wheel because I occasionally have my eps come on when getting on the freeway fast on a cloverleaf entry. It is disconcerting the first time it happens. It feels like someone is hitting the brakes while you are trying to accelerate.
Have fun!
Thanks for the advise and yes this particular kit comes with front and rear track bars and adjustable sway bar links.
Originally Posted by JPSquad
Sounds like a good time. If it's alright, I'd like to come and help out. PM me the info if it's alright.
Cool I'll PM you when we get it all figured out. Still looking for a location.
Old May 31, 2010 | 08:25 AM
JK08MCS's Avatar
I have two tall jack stands, but I don't think I can make it that Sunday, (family from Florida ). If you want we can meet Saturday, so you can use um .
Old Jun 1, 2010 | 03:34 PM
Set the date for Saturday 10 am. Can you make it?
Originally Posted by toad
I have tall jack stands as well. I can always get them to you since we're pretty close. I'll have to see if I'm available on Sunday. I said I would help out my niece taking some pictures. I'll let ya know.
Yeah, if I could get your stands we can work on the front and rear at the same time. Let me know if you can stop by or if I need to go to your pad and pick it up.
Old Jun 1, 2010 | 03:41 PM
artpics's Avatar
grats on the lift. Hope all goes well i am in London
Old Jun 3, 2010 | 08:01 AM
Serg5000's Avatar
I also have tall jack stands. PM me if you need anymore help.
I can bring tools as well if we need anymore.
One more thing, what exactly is the lift? Is it a full suspension lift or just a coil lift like I did. I want to bring the proper tools if you need me to help.
Old Jun 3, 2010 | 11:41 AM
TwinDad is bringing some air tools and I have the air compressor.
Old Jun 3, 2010 | 05:22 PM
JK08MCS's Avatar
Toad, I have the rest you speak of (Stands and Torque wrench)
Old Jun 3, 2010 | 06:30 PM
Serg5000's Avatar
I have two tall jack stands I could lend. I looked at my schedule and I may have to work that saturday. I could bring them out to Santa Clarita and meet you toad. Or were ever you think is a good place to meet up. Any time between now and sunday works for me.
Old Jun 3, 2010 | 07:16 PM
JK08MCS's Avatar
I have, the bottle, the floor, and the 60" high lift jack. I'll bring all three with the two 6 ton stands and the ft/lb torque wrench. I had the torque wrench calibrated at work, so if you guys want to check what you got...
Old Jun 4, 2010 | 04:12 AM
Wow. Just got home from work and it seems you guys were busy on the thread. Thanks and I'll see you all Saturday.
