Huntsville Alabama / Tennessee Valley Chat
Old Jul 21, 2010 | 04:17 AM
  #4671
sixty5vdub's Avatar
Who all is carpetless?
Originally Posted by jeepoholic
My wife is.
Originally Posted by Wilky
Good plan...I'll PM you my address so you can have my gussets/sleeves sent to my house
Let's all just get a group buy on gussets and sleeves. You all know you wanna ............
Anthony
Old Jul 21, 2010 | 04:22 AM
  #4672
08RedRecon's Avatar
Foudn this Do it Yourself front end alignment info:
http://project-jk.com/jeep-jk-write-...-end-alignment
I found it useful
Old Jul 21, 2010 | 07:15 AM
  #4673
burbingus's Avatar
Originally Posted by 08RedRecon
Are you doing the work yourself or paying someone to do it?
Edit: Disregard, went back a page to see youre looking at Rocket City Offraod. Be curious to hear what the quote you for labor.
For the front and rear axles, gears, and lockers and the front sleeves and gussets he quoted ~1500. I wanted to do these myself, but I haven't done any diff work before, only axles, and want to be sure it's done properly.
I found it useful
This guide looks pretty good - I think I'll be referring to it after I install the lift. I think the alignment will take a good long time as it'll be the first time I've done it on this vehicle.
That is a good write-up, but won't get you exact. I found it super useful when installing the Trailmaster lift, but I highly recommend taking it to NTB and getting the "free" computer alignment to see where you sit. I discovered that the C's on the axle aren't uniform and was getting 6.1 and 6.8 degree readings on driver/passenger side caster. Once it was on the computer at NTB, it turned out to be 5.1 exactly on both sides....a little bit of a misreading using the Harbor Freight magnet angle-finder
How you liking the lift so far?
Yeah I was definitely planning on taking it to an install place for tire balancing and to double check the alignment. Good call.
Old Jul 21, 2010 | 07:47 AM
  #4674
08RedRecon's Avatar
Unsure how like the lift so far, havent had it out of the garage yet. I messed up the draglink end that goes into the pitman arm while installing a new pitman arm that lowers the drag bar. Awaiting new part from Quadratec.
Old Jul 21, 2010 | 07:49 AM
  #4675
08RedRecon's Avatar
Also, I agree with taking it somewhere to dial it in. This will definitely get you in the ballpark. PLus it helped me understand better what is going on with the vehicle. I never could understand what people were talking about when they said "castor". Now i know.
Old Jul 21, 2010 | 08:24 AM
  #4676
jeepoholic's Avatar
When you go to buy your gears and gussets go to 4x4groupbuy.com. I bought my TeraFlex lift for $500 cheaper then anyone else, also bought my superior axles for $120 less than anyone else.
Call and talk to Jason he is the owner and just tell him that Jayson that bought the TF lift and axle shafts told you to call and he'll give you a break on the price.
Old Jul 21, 2010 | 09:03 AM
  #4677
08RedRecon's Avatar
Yep, the explanation (and pretty drawings) really helped me understand how complex everything is and how pertinent it is that they all work together. I can't even imagine how an IFS explanation would be
So you opted for the dropped pitman arm??? I asked the techs at Trailmaster if it was needed with this kit (or the highsteer option) but they said it wasn't. I think I might still get one though b/c it's supposed to reduce all steering issues.
Yes I did. The angle is so steep without it. And after experiencing death wobble after the initial install, I am about willing to do anything to correct the geometry as much as possible. The wife also experienced the death wobble and that was not a pleasant one way conversation she had with me once she got it pulled over.
Old Jul 21, 2010 | 09:04 AM
  #4678
08RedRecon's Avatar
I did not realize they were so much cheaper than others, will check them out. Thanks for the insight.
Old Jul 21, 2010 | 11:21 AM
  #4679
burbingus's Avatar
I'm shopping the Trailmaster kit for the Unlimited, and it's $1775 from Quadratec. Everywhere else it's between $2200 and $3000. Is Quadratec running an older generation or something? How much did your kits run?
Old Jul 21, 2010 | 11:31 AM
  #4680
08RedRecon's Avatar
$1775 sounds about right. Kit hasnt been out long so it cant be an older version
