Huntsville Alabama / Tennessee Valley Chat
Old Aug 24, 2010 | 04:31 PM
  #5171
ASTE25's Avatar
Originally Posted by 08RedRecon
Aste25
In the upper right hand corner, click on "settings". The click on "edit settings" on the left side of the screen. Under staging area, select "The South" from the drop down menu.
I'm not sure if that's what I'm talking about or not. I have my staging area set as "The South". Is there a group called "the South" as well?
Old Aug 24, 2010 | 05:06 PM
  #5172
JK-Rubi's Avatar
Default Hemi
Ahhh Haaa!! I knew you were up to something early last week when I asked about your battery box not fitting with your new Hemi . . . you rascal.
Originally Posted by JK-Rubi
Anthony - I was doing more research on the dual battery setup I mentioned up stream, and noticed you'll have a stock battery box available soon. Are you also going to the dual system, or will your new Hemi not accommodate the stock battery carrier?
Originally Posted by sixty5vdub
A couple of teaser pix:
Old Aug 24, 2010 | 05:25 PM
  #5173
Divescaves's Avatar
Originally Posted by racinfast002
Doors are permantly off until it calls for rain again (Yes I'm excited)
Top, doors, frame unbolted and taken off......................
Old Aug 24, 2010 | 05:39 PM
  #5174
08RedRecon's Avatar
Thats the only thing Im aware of.
Old Aug 24, 2010 | 05:40 PM
  #5175
08RedRecon's Avatar
Are you doing the install?
Old Aug 24, 2010 | 06:38 PM
  #5176
uofagrad05's Avatar
Here is my next mod, 26" rims.
Is it just me or does that look like a modern day wagon.
Old Aug 24, 2010 | 07:26 PM
  #5177
JK-Rubi's Avatar
Default Soft Top Leaks
Stumbled across this interesting thread - haven't had Wilbur in the rain much, but when I have, he's stayed nice and dry inside. If I ever end up with a leak problem, may try this fix.
https://www.jk-forum.com/forums/show...=1#post1127119
Old Aug 25, 2010 | 04:15 AM
  #5178
sixty5vdub's Avatar
I thought the exact same thing. I dunno if it is the rims/tires, or those side steps. But it looks like the new 2012 Stagecoach Edition.
Yep. Just couldn't justify spending that extra $10k or so to have somebody else do it. At least not to the CFO .............
3.8L should be coming out this weekend. I may have a line on a low mileage 5.7L in the near vicinity ....... still working on that. The transmission will be the easy part. Those are a dime a dozen. But the engine is proving a little more challenging to find. At least one in the right price range is.
Anthony
Old Aug 25, 2010 | 04:27 AM
  #5179
sixty5vdub's Avatar
Guilty ............
Anthony
Old Aug 25, 2010 | 06:38 AM
  #5180
sixty5vdub's Avatar
Originally Posted by randy payne
Anthony, my sister hunts parts at her job she can do a search and c what she finds, just need to know exactly what your lookn 4
PM sent!
Anthony
