OR-Fab NEW Rear Corner Armor
Old May 18, 2011 | 03:57 PM
  #101
stevedolce's Avatar
Default cost?
did we see a pre order price yet? and how would they attach?
Old May 19, 2011 | 08:12 AM
  #102
yhudson's Avatar
Sponsoring Manufacturer
Originally Posted by jonboy
Am I wrong to assume they will come powder coated, or will there be a bare steel option?
Normally they will be powdercoated (Wrinkle or Bike Black), but on the pre-order you'll have an option to order bare steel (and save some $$$).
Mostly with Riv-Nut-serts and a couple of "thru bolt" spots. The pre-order pricing for the "Gecko Skins" will be $349 plus freight for the ones without slider bar, and $469 for the "Gecko Skins" w/ Slider Bar (I know I earlier said they would be $180 more, but I misspoke, that's the difference between the two in MSRP).
This pricing includes the light kits and powdercoating. Pre-order dates are being set for about mid-june.
Yates
Old May 19, 2011 | 11:44 AM
  #103
Grognard's Avatar
What would the cost be to preorder the skins with slider bar bare steel for a JKU?
I would like to powdercoat locally like I did my bumpers and rocker armor so it will all match.
Old May 19, 2011 | 01:48 PM
  #104
jja's Avatar
jja
Question on the license placement . I just installed an OR-Fab tire carrier and with the T-handle for the spare tire the usual spot most people re-locate their license plate to won't work. So if I get these corners where does the license plate go ? .. If it's back in the OEM location will their be a provision for the OEM plastic thing to re-attach ?
or did I miss that you've decided to include a license bracket ?
Old May 19, 2011 | 02:53 PM
  #105
rattler_thesnake's Avatar
Yates
Dude..get these out before I waste my cash on something important like, booze and hookers....
Old May 20, 2011 | 02:21 PM
  #106
yhudson's Avatar
Folks that what their Gecko Skins plain will save $20 on powdercoating. So the JKU version with the bar is $449 plus shipping.
I'm not certain what folks are going to do for license plate relocation. Given the feedback we've gotten back from this forum and field surveys our R&D made both versions with NO LICENSE PLATE provision.
Since you just purchased our tire carrier, I'm sure I can get them to fab up a plate similar to what they've done for me. You'll attach it the the t-bar handle and have to wire it up so that the led lights up when your lights are on, but that's not too hard. They are working on another relocation kit that will attach to the bumpers, so the kits aren't OR-Fab specific.
Sir, supporting the booze and hooker industries is never a waste!
Yates
Old May 29, 2011 | 11:03 PM
  #107
Kachad's Avatar
Yates
I would suggest staying away from the wrinkle powder coating. Due to the chemistry of this coating, it typically has reduced corrosion resistance, unless it's coupled with a primer - and in that case your production cost will increase significantly. For the quality conscious buyer, this increase in cost would be well worth it, but you would have to run the numbers.
I believe the Bike Black is a 85+ Gloss coating and what is considered a "General Industrial Grade". Personally, I wouldn't like a high gloss coating on that type of part. There are "Super Durable" grades out there that would resist UV degradation alot better, for slightly more cost (5 years without significant gloss fade for the super durable versus 1.5-2 years for the general industrial).
If you're going with a single coat system, I would suggest two possibilities:
1: A textured super durable powder coating (not wrinkle) that is formulated for a slight texture that still retains good corrosion resistance. I've coated my CJ-5 grill with this about 10 years ago, and the finish has held up very well.
2: A 30 gloss (or close) smooth super durable powder coating. This coating will hold up slightly better then the texure, but avoid that glossy look.
Also, please do your homework when sourcing your coater for the parts. Pretreatment of the steel is essential to long term corrosion resistance, and many manufacturers shop for the lowest cost trade coater for their work - avoid that.
Old May 30, 2011 | 08:30 AM
  #108
Baddintentions4u's Avatar
Yates
I am SO ON THESE!!! Can't wait for pre-order!! Give me a good deal/ quote on the tire carrier with rotopax, bumper and rear corner armor.
Old Jun 7, 2011 | 02:15 PM
  #109
Default Any update
Any update on these.......
Old Jun 7, 2011 | 02:21 PM
  #110
peanut's Avatar
Hope soon I need them
