May Special: Onboard-Air.com Economy Onboard Air System
Old May 3, 2012 | 03:58 PM
Air Werkz's Avatar
Former Vendor
Default May Special: Onboard-Air.com Economy Onboard Air System
We will be doing monthly specials from now on, for each month. To kick things off, we will doing 2 this month. Feel free to PM, Email or Call us with any questions.
sales@onboard-air.com
480-442-8136
May Special:
This will be for our very popular economy OBA system.
Regular Price: $299
Sale Price: $275
Just enter "May1" as your coupon code.
400C Economy OBA System
This economy 150 PSI kit is specifically designed as a compact, affordable onboard air system that utilizes the VIAIR 400C compressor and 2.0 gallon. We designed this kit for those that want a an OBA system, but without the price associated with it. This onboard air system is affordable, by giving you just the essential components needed to have a high flow 150 PSI capable onboard air system. This system uses the VIAIR 400C compressor, 2.0 gallon tank, relays, pressure switch & air relocation kit.
Specifically designed for Jeep using the smaller 2.0 gallon for easier installation.
Included Parts:
- (1) 400C Compressor (Patents Pending Intercooler Head)
- (1) 2.0 Gallon VIAIR 150 PSI Air Tank
- (1) Air Source Relocation Kit
- (1) 40-Amp Relay with built-in 110 PSI - 145 PSI Pressure Switch
- (1) Tanks Fitting Kit (Drain, 175 PSI Saftey Valve, Plugs)
- (1) Air Filter Assemblies
- (1) Remote Mount Brackets
- (1) Sets of Remote Mount Fittings
- (1) Sets of Spare Air Filter Elements
- (4) Sets of Nuts, Bolts, Washers and Lock Washers
- (1) Stainless Steel Braided Leader Hoses with Inline Check Valve
- (3) Airline Clips
Specifications:
12-Volt
Permanent Magnetic Motor
Duty Cycle: 33% @ 100 PSI
Max. Working Pressure: 150 PSI
Max. Amp Draw: 26 Amps
Max. CFM: 2.54
Fill Rates:
33"x12.5"
0 To 30 PSI: 4 Min. 00 Sec.
15 To 30 PSI: 2 Min. 00 Sec.
35"x12.5"
0 To 30 PSI: 4 Min. 50 Sec.
15 To 30 PSI: 2 Min. 20 Sec.
Old May 6, 2012 | 06:16 PM
4W-Jive's Avatar
Do you have pics of this mounted up? Seems like a great deal, not too sure why this thread doesn't have any activity on it.
Old May 6, 2012 | 08:18 PM
Bxjk's Avatar
X2 on some pix mounted. I'm subscribed!!
Old May 7, 2012 | 09:15 AM
Air Werkz's Avatar
Former Vendor
I don't have any pictures of it mounted since it is a "universal" kit. I will see what I can find though. I know a lot of guys will fab up brackets to mount the tank along the frame rail on the drivers side.
I will keep you all posted if I can locate some images.
Old May 7, 2012 | 10:11 AM
4W-Jive's Avatar
Is this capable of running tools in small bursts?
Old May 7, 2012 | 10:32 AM
Air Werkz's Avatar
Former Vendor
Absolutely.... This is basically the same as a VIAIR 10005, and uses the same compressor. All components in this system are VIAIR products.
This economy system just has the essentials for an OBA system, and you supply the fill hose, and wiring.
You can pull all lugs off your wheel, and by the time you get the other wheel, the tank will be charged and ready to go again. Die grinders take a ton of air, so very small spurts there. Blow gun and everything else is good in bursts.
Old May 7, 2012 | 10:41 AM
maddmatt9400's Avatar
You stated "2 this month".... what's the other special?
Old May 7, 2012 | 11:37 AM
Air Werkz's Avatar
Former Vendor
Our other is the JK specific OBA systems by VIAIR. You can see the JK-Forum special here.
Old May 10, 2012 | 11:55 AM
Air Werkz's Avatar
Former Vendor
This system can also be upgraded with a 2.5 gallon tank for an extra $5.
Old May 15, 2012 | 07:36 AM
Durangoman's Avatar
