NEW ORA Night Guard LED Headlights
[/I] (Update 1/6/15 These are fully stocked ready to ship! We also have anti flicker harnesses available and we are now giving free shipping to forum members as well! If you already asked for a quote we will send you a PM with the coupon code, and if not reply to this thread for the code. Thanks! [/I]
Upgrade inadequate stock Jeep headlights with new ORA Night Guard LED Headlights!
Direct plug-n-play with the factory wiring harness and plug; installs in minutes and no hard wiring required!
Built to the specifications of Department of Transportation, not yet certified.
Daytime running lights included, without buying costly aftermarket accent lighting or halos.
Running lights can be used with a separate switch or as constant running lights.
Low beam gives off a mid-width beam pattern and high beam gives off a powerful spot beam reaching for hundreds of yards!
Specially designed cooling fins on the housing are the only style which fit perfectly with Jeep JK (2007+) Wranglers!
Military grade breather allows pressure equalization without compromising waterproof rating, preventing headlight fogging.
IP 68 waterproof rating ensures a water tight headlight which will not fail due to moisture or dust intake.
A one year full replacement warranty provided by Off Road Additions LLC gives the customer the confidence in a quality product.
4D optics spread light where it is needed most in an optimal pattern.
These headlights will have a small flicker when used with the Jeep JK's electronics. We now have our own anti flicker harnesses available correct this!
Exact Specifications
LED Power: 75 Watt Total
Beam type: High/Low Beam with Running Lights
Operating Voltage: 12V or 9-32V DC
Waterproof rate: IP 68
13 pcs of 5 Watt High Intensity Osram LEDs
Optional Colors: Black
Color Temperature: 6000-6500K Cool White
Added Lights: Daytime driving and Parking Lights
50,000 hours average LED life time
Dimensions: 7 Inch Round
Lumens: Per Pair - (Low Beam approx. 1,750) (High Beam approx. 3,700)
http://www.offroadadditions.com/ora-...ed-headlights/
Price point will be very competitive with other popular headlights.
And since you asked I will post another picture!
Edit: Having trouble uploading photos at the moment. Don't worry though full information is fast approaching.
