New! Soon to be Released 2012-Up JK Bolt-on Air System
Old Jan 28, 2013 | 04:06 PM
  #31
Air Werkz's Avatar
Former Vendor
Originally Posted by azsandrider
Can you post up underneath side views?
How protected will the tank be?
Are you considering adding an option of a protective skid plate to protect the tank?
I can foresee slipping off a boulder and landing on the tank.
Here is a picture from the side. The new bracket we will be fitting up soon, is going to be adjusted up 3/4" to maximize ground clearance. After we test fit this, depending on where it hangs, we will detemrine if we need a optional skid plate. If it does, we will create a 1/4" thick steel skid plate plate to help protect it. Even if it doesn't hang below, we might anyways for extra insurance. The tank will have the drain at angle, so to keep everything as high as possible.
Bracket before moving up 3/4".
Old Feb 11, 2013 | 04:21 AM
  #32
StrizzyChris's Avatar
May be a silly question, but how much are these systems affected by water and mud?
Old Feb 11, 2013 | 08:55 AM
  #33
Air Werkz's Avatar
Former Vendor
They will come with filter relocation kits, so that you can put the filter inside the cab or to a dry location. With doing that, they are very well sealed up against water and mud and will handle the elements without problems.
Old Feb 16, 2013 | 09:05 AM
  #34
jsands's Avatar
Estimated availability date?
Old Feb 18, 2013 | 06:23 AM
  #35
Air Werkz's Avatar
Former Vendor
We were hoping to have it already available now, but I would say end of March to be on the safe side. Then we will be ready and shipping production units. We are excited to launch this new kit, so we are pushing forward but also taking time to make sure we get it 100% before releasing.
Old Feb 18, 2013 | 06:37 AM
  #36
jsands's Avatar
Cost estimate?
Old Feb 18, 2013 | 06:39 AM
  #37
Air Werkz's Avatar
Former Vendor
We are right now estimating around $519 with all the fittings, stainless hardware, etc. It will be a complete kit with everything you need.
Old Feb 18, 2013 | 06:51 AM
  #38
jsands's Avatar
Compressor and all?
Old Feb 18, 2013 | 06:55 AM
  #39
jsands's Avatar
Are you taking pre-orders?
Old Feb 18, 2013 | 07:04 AM
  #40
Air Werkz's Avatar
Former Vendor
Yes, that will be the compressors, 3-gallon aluminum tank, etc. Yes, we will be taking pre-orders but wanted to wait until the order was in for the final production units. I should have pricing back today or tomorrow for the brackets, and from there I can get an actual kit price. Maybe then, we can take pre-order.
We will offer a few version. The lower 105 PSI system will be for air locker use.
Options:
Single Compressor: 105 PSI
Single Compressor: 150 PSI
Dual Compressor: 105 PSI
Dual Compressor: 150 PSI
So far, the kit will be including:
Mounting Bracket
VIAIR 400C Compressor (single or dual)
3 Gallon aluminum air tank
80A relay built into the bracket
Stainless mounting hardware
All necessary fittings (DOT approved, Push-To-Connect)
Remote mountable air coupler
Remote mount coupler bracket with hardware
Fill hose w/ tire chuck
BSP adapters for air locker valves (with 105 PSI kit)
