TPMS Questions (!)
Old Sep 2, 2010 | 06:47 AM
The_Yeti's Avatar
Default TPMS Questions (!)
Ok so here is a thought I don’t know if anyone makes this without having to buy a kit in which replaces the valve stems. Sponsors/vendors food for thought.
It’s obvious that the TPMS is annoying but is there a way to make it work to our advantage? This is assuming that the sensors transmit the actual PSI in the tire. Is there anything that will plug in to the jeep or wirelessly receive the signal from the TPMS sensors to tell you what the pressure is in your tires?
From what I have seen you can adjust the PSI in which the light trips on the dash using Pro-Cal? so one would think that the computer knows the current PSI
