Tuffy Security Deck Enclosure Pictures
Old May 1, 2009 | 05:29 AM
  #21
jayrav's Avatar
I'm not sure if I want to add this to my list since I would have to sacrifice my rear seat.
Old May 1, 2009 | 05:46 AM
  #22
TwinDad's Avatar
Any idea if the fredom top panels will fit under the deck?
Old May 1, 2009 | 06:15 AM
  #23
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
will your freedom panels lay down in the back now? I dont think they do, but if they do then they should fit
Old May 1, 2009 | 06:25 AM
  #24
tuffy2's Avatar
Sponsoring Manufacturer
I just checked it out and they fit perfect even with the factory subwoofer speaker. As a matter of fact with the speaker in, it is a perfect fit that would keep them from sliding around. Put a blanket or pad between them and they stack like the enclosure was built just for the panels.
Old May 1, 2009 | 06:35 AM
  #25
TwinDad's Avatar
You beat me to it. I just checked too
Glad to know they will still fit. This is definitely on the short list now!
Old May 1, 2009 | 06:50 AM
  #26
08UnlimitedSahara810's Avatar
I am very impressed with this piece and will probably order one.
Do you know if you can still use the latch system for car seats? Very improtant in my life since we have number 3 on the way!
Old May 1, 2009 | 10:38 AM
  #27
tuffy2's Avatar
You can still use the latch system for car seats.
Old May 1, 2009 | 11:09 AM
  #28
TwinDad's Avatar
I was looking at the installation instructions and it looks like the top tray is on rollers that would allow it to be pulled forward for access. Is it?
Old May 1, 2009 | 01:10 PM
  #29
tuffy2's Avatar
The top tray does slide part way and then hinges up for access. It doesn't slide all the way out until you lift it out of the track "slots" and then it will push all the way out for removal.
Old May 1, 2009 | 03:51 PM
  #30
somewhereinla's Avatar
This is very exciting.
A couple of questions: Do you have any pictures of it in the 2drs? and especially important for the 2 drs, can it be un-mounted/removed easily for times when putting the back seats on if needed? Do you need to even remove the back seat, or can it be mounted with the back seat folded? and can you remove the back and top panel and unfold the seats? is that possible?
Great product I definitely want one if it is modular.
cheers.
