Two NEW OR-Fab Products
That item is "in the works". They are planning on doing the proto-type on my jeep, which will be back this coming Sunday. The R&D guys will have it until the next Rubicon (Aug 16), to get something in place to test. Let Jake know when you'll be ready to test a proto-type and he'll get you lined up.
Thanks!
Yates
Thanks!
Yates
Quick question here. The stock sport bar also provides some additional support for the windshield, is there decrease in rigidity of the windshield without that bolt on?
I'm definitely interested in this cage also.
Sponsoring Manufacturer
JK Sport Cage
Glennco our sport cage also bolts to the windshield to maintain the stock rigidity of the veichicle. The windshield bracket is constructed of 3/16" plate that is laser cut and bent in one of our CNC press breaks. What’s cool about the windshield bracket is if you want to lay open the windshield our bracket will also unbolt from the sport cage to give you a cleaner look.
Do you not need the bars that go between the sound bar and the windshield? Any pictures with the windshield up and of how it mounts to the sound bar? Also do you have anything going from the sound bar to the rear cage crossmember? Sorry for all of the questions but I was just about to order the rockhard cage. I think I may have to wait!!
JK Sport Cage
Our Sport Cage windshield bracket/mount is bolted to our sport cage and then bolts into the stock location on the windshield side. This can be easily unbolted so that you can open and close the windshield.
The bars at the top of the cage in the center our called streamer bars they add additional support to the sport cage. This is the same as our TJ sport cage. All you do is drill a couple of hole and use our self tapping bolts.
I will post more pitchers as we go so everyone will understand the construction of our Sport cage. The sport cage is out of the jeep right now. We are welding the dash bar in place and sending back to powder coat.
When we put the sport cage back in I will get better photos of what you guys want to see.
