WIN the TeraFlex CRD60R Rear Axle Giveaway!!
#930
I need some upgrades!!
To help celebrate the 10th anniversary of making off road specific axles, TeraFlex will be giving away a brand new JK CRD60R Limited Slip with choice of gears to one very luck member here on JK-Forum.com!!
JK CRD60R Features
The original & industry leading aftermarket high pinion Dana 60
Stronger bracketry than factory OEM
JK specific CNC laser cut bracketry from 1/4 steel provides the highest strength
Run 38 tires with confidence
Maximum control arm & trackbar adjustability with multiple mounting locations
Maintain factory drivability & sensor control system information
JK ESP, ABS & speedometer sensor compatibility
Proper pinion angle for lifted JK applications to maximize power transfer JK CRD60R Features
100% engineered, designed, and built in the USA
CAD designed housing & bracketry for precision
Proven tri-chamber oil system for maximum oil flow to critical bearings
Maximum ground clearance (more than a Dana 44)
HD oversized outer pinon bearing for superior strength & heat reduction
Off-the-shelf bearings and parts for easy maintenance & repair
Housing features cast ribs & gussets for strength to resist deflection
Thicker axle tube than factory - 3 OD DOM tubing
Premium UV protected powder coating for superior quality finish
Smooth radius bottom to glide over rocks and obstacles
HD 3/8 cast cover for extreme rock protection defense
100% new components used throughout for a true 0-mile axle
No Excuses warranty - 1 year, unlimited mileage JK HD Axle Shaft Features
Rolled splines for a stronger shaft vs. cut splines
4140 Chromoly shafts with dual wheel bolt pattern (5 on 5 or 5 on 5.5)
Axle shaft profiling for improved shaft strength and fatigue resistance
35 spline shafts provide maximum strength and interchangeability with lockers
Complete with axle assembly, axle shafts, HD cover Stronger bracketry than factory OEM
and Limited Slip Trac-Lok, this Giveaway is valued at over:
$2995.99
To WIN:
You need to be a registered member of JK-Forum.com.
You need to post (1) ONE response in this official registration thread.
You need to include a photo of your JK in your post.
You need to post your response on or before 12:00 NOON-PST, May 3, 2011.
A member will be selected at random to win this prize between the hours of 5:00 and 7:00 PM-PST, May 3, 2011. A Private Message will be sent to the member in question and an announcement will be made in an official thread posted in this forum:
The selected member WILL BE REQUIRED to be logged on to JK-Forum.com and will have a total of 5 minutes to post a response in the official announcement thread. Once the official announcement thread is created, NO other member will be allowed to post in it except for the member selected to win the prize. IF the selected winner is not present or fails to post a response on the official announcement thread within the 5 minute time frame, a new winner will be selected and announced accordingly. This process will be repeated until a winner is present to claim their prize.
If the winner is located outside of the lower 48 United States, they will be required to pay for ALL shipping costs and tariffs.
JK-Forum.com reserves the unconditional right to make changes to any and all forum Rules and/or Guidelines, including those created for special events and/or giveaways, at any time and without any prior notice. JK-Forum.com also reserves the unconditional right to determine the winner of this giveaway and, if deemed necessary by JK-Forum.com in its sole discretion, to cancel the giveaway at any time.
There is NO cost and NO minimum post count required in order to enter this giveaway. Manufacturers and vendors may not enter into this giveaway and will not be eligible to win.
Multiple posts in this official registration thread will disqualify you from the drawing.
Entering this giveaway under multiple user accounts will result in the termination of ALL your accounts.
You MUST be 18 years or older to win.
Good luck to all of you!! You need to post (1) ONE response in this official registration thread.
