[B]Screw the Doors?[/B]
I've had them out since the first time I took the doors off. Having them off does not really change the security of the Jeep. If you notice the actual door panel, the panel is designed such that the door would have to be open to remove the doors(there are interference issues with the metal if it is closed)
Originally Posted by EVERYBODY ON THIS THREAD
took torx off, left them off
I did notice something though... when removing the door, gotta open it all the way, like, 90 degrees from the body. The part of the door under the hinge hits the hinge when removing the door if its not opened wide. If the door isn't opened wide enough (for those worrying about crashes, etc) it won't pop off. Besides, as long as it's latched closed, it shouldn't go anywhere anyways.
plk457, perhaps this is your problem?
the first time I tried removing them, i kept hitting the little flange of metal under the hinge. For the front doors, I nearly had to have the mirror almost touching the front fender.
For as little time that it takes to put them in, I just go ahead and do it. I mostly do that so I dont have to worry about losing the screws.
Gravity is the real force that keeps them in place.
I'd say the door ways less than 30 lbs. The only thing I can think is that you didn't open the door wide enough.
..... Everyone else, thanks for the thoughts/advice. Drove around today with no screws & will probably keep them in that little "storage trunk" in the back. I thought about the roll-over condition also... the door can't come out until it opens because of the hinge design, and if the door is open in a roll-over it's not doing me any good anyway...
wouldn't be there if they weren't needed
The first time I took the doors off, I put the screws in a zip-lok bag and put in the storage compartment in the rear and I haven't seen them since. I have 52K miles on the Jeep without incident. The only time they will go back on is if I sell it and whoever buys it puts them on.
I don't understand what their purpose is. If the door is open, the weight holds them in place. If the door is closed it's locked and they can't come off anyway... Seriously, what are they there for??
Actually, I just remembered that they are in my glovebox from last weekend. They don't seem to be rattling too much, but I'll probably put them back on for the winter or something...
