08 Engine Concern
08 Engine Concern
Hey Guys,
So this morning I got into my jeep and turned the ignition on and sat there for a few minutes. I then put it in drive and all of a sudden I hear a knocking sound coming from the engine compartment. Ive never heard this noise before and it only happened when in drive. I tried putting it neutral and then park with no noise replicated but then once in drive and the knocking sound came back.
Anyone ever experienced this?
Its an 08 with 75k miles and no lift (i know...soon).
Possibly no one has replied because from your description is could be several things. It could be an engine problem with something as severe as a rod knocking under load. It could even be a front axle/drivetrain issue.
Sorry but it is kind of hard to tell from here. Have you checked the engine oil? Does it burn or leak oil? Has it ever been run low on oil?
Engine oil is good and it burns but very little if any at all. I constantly check my oil so never gets low enough for concern. I listened for it today and heard nothing so I'm just going to chalk it up as a jeep noise for now unless it comes back.
dude, its a knock. happened to my JKU at around 104k. weird knock/ping only in drive, only hearing during acceleration at times, anyways, crank snapped and i need a new engine...but if its more of a metal rattle you can check out the CATs, those also went out on me...lol screw this jeep. i think i just got a bad model. still love this piece of shit.
it definitely was a weird knock/vibration but I wasn't accelerating I had my foot on the break and it was in drive I was getting ready to take off but wanted to set my phone up first and thats when i noticed it.
Is it still happening?
Any chance it's transmission related?
Have you serviced the trans yet? Check the fluid level and color.
If oil is good, check spark plugs. Check the easy/cheap things first. I wouldn't let it go and chalk it up to anything but a sign. It may have been something that self resolved like a cat stuck under the hood (as it gets cooler, all sorts of mammals will climb up into engine compartments to get out of the wind) but that too may have messed up things.
Next thing. Did you rebuild or swap new motor?? Cost?
Hey Guys,
