10,000 miles between oil changes?
Would you feel comfortable going 10,000 miles between oil change intervals?
Right now, I have my engine oil changed at the dealership for $32-ish. If I could go 10,000 miles between oil changes this would be very cost effective!
SAE 5W-20 XL Extended Life Synthetic Motor Oil Product Code: XLMQT-EA
AMSOIL XL Extended Life Synthetic Motor Oils provide better wear control, high- and low-temperature protection and increased fuel economy compared to conventional oils. Formulated with extended-drain boost technology, AMSOIL XL Synthetic Motor Oils provide superior performance for up to 10,000-
SERVICE LIFE
In gasoline-fueled vehicles, AMSOIL XL Synthetic Motor Oils are recommended for up tp 10,000-mile/six-month oil change intervals or longer when recommended in owner's manuals or indicated by electronic oil life monitoring systems. Change aftermarket, original equipment manufacturer or AMSOIL Ea Oil Filter at every oil change.
SERVICE LIFE
I am on the same schedule with Royal Purple Full Synthetic. I change the filter at the half way point and top off. Full Synthetic in the axles, transfer case, transmission, and engine is the only way to go!
Wow, I must be old school... I still change my oil every 3k like clockwork, with a tire rotation. I always have on every vehicle I've owned. I couldn't imagine going 10k on anything but a tractor trailer. But I'm stubborn.
I change my oil and rotate my tires every 3,000 miles. Cheap insurance. most of the people advocating longer oil change intervals are the tree huggers/enviromentalists. No offense to trees, but ill stick with my old fashioned thinking and do my regular oil change. I actually enjoy doing it.
I'm sure 5k is fine and I probably wouldn't worry too much if I HAD to go 5,000 rounds for my next oil change. But I feel better at 3, and it's not going to hurt.
You could probably go weeks between brushing your teeth, but would ya?
P.s. It's good to see I'm not the only one stuck in the 3,000 mile state of mind.
