'12 Soft top window question
Old Jun 19, 2012 | 12:37 PM
Black12's Avatar
Default '12 Soft top window question
Are the windows supposed to tuck into the plastic pillars next to the backseat headrests or is the little 90 degree lip in the window supposed to just get held shut by the closing doors? Make sense?
Old Jun 19, 2012 | 12:44 PM
Gcollura's Avatar
They should be tucked in.
Old Jun 19, 2012 | 12:47 PM
Noxian's Avatar
Tucked in, they should hold themselves in place once the zipper is done up and the bottom is snapped in.
I usually zip up about 4-6 inches of the zipper,
Tuck in the side into the door frame,
clip in the bottom, then finish zipping up the zipper.
Old Jun 19, 2012 | 12:48 PM
bushpilot's Avatar
you dont say if youre a 2 door or Unlimited 4 door....
ON MY 2 Door - mine tuck in to the plastic surround via a plastic lip.
I've got my windows out (finishing speaker installs or id snap a pic for you.
there is a channel on the B pillar (plastic surround) the FRONT VERTICAL edge folds into this channel (and the door seal closes against it.
Old Jun 19, 2012 | 12:52 PM
Noxian's Avatar
His profile says 4door, but I am pretty sure the 4door and 2 doors are the same in the way the rear windows attach.
Old Jun 19, 2012 | 07:05 PM
ThreadHijacker's Avatar
yes my 4 door is the same
Old Jun 20, 2012 | 05:24 AM
Black12's Avatar
Thanks for the info. Finally got it. New jeep. Took a lot of pulling to get that window tucked in. But... no more flapping.
Old Jun 20, 2012 | 07:21 AM
g3cko's Avatar
There was another thread with the same question. I will admit i wasn't sure at first either. I think jeep needs to revise the instructions.
Old Jun 20, 2012 | 07:34 AM
arjeeper's Avatar
They tuck around the corner tightly. I wasn't sure the first time I tried to put my windows back In either.
Old Jun 20, 2012 | 09:20 AM
Gforce!'s Avatar
From: Independence and Lexington, KY (depends on the time of year)
They tuck, I find it easiest to zip the window 3-4 inches, tuck the window in, then get the bottom plastic piece tucked in, an then zip and Velcro the rest.
