'12 Soft top window question
Are the windows supposed to tuck into the plastic pillars next to the backseat headrests or is the little 90 degree lip in the window supposed to just get held shut by the closing doors? Make sense?
Tucked in, they should hold themselves in place once the zipper is done up and the bottom is snapped in.
I usually zip up about 4-6 inches of the zipper,
Tuck in the side into the door frame,
clip in the bottom, then finish zipping up the zipper.
you dont say if youre a 2 door or Unlimited 4 door....
ON MY 2 Door - mine tuck in to the plastic surround via a plastic lip.
I've got my windows out (finishing speaker installs or id snap a pic for you.
there is a channel on the B pillar (plastic surround) the FRONT VERTICAL edge folds into this channel (and the door seal closes against it.
From: Independence and Lexington, KY (depends on the time of year)
They tuck, I find it easiest to zip the window 3-4 inches, tuck the window in, then get the bottom plastic piece tucked in, an then zip and Velcro the rest.
