19/60 coil swap/rake question
Old Nov 19, 2014 | 08:24 PM
thefourth's Avatar
Default 19/60 coil swap/rake question
I know there's a lot of threads about coil swaps, but I couldn't find anything about what putting 19/60 coils on your stock jk will do to the rake.
I hear a lot of people say they added 1 1/4 inches lift in the front and 1 3/4 inch in the rear, but won't that increase the already raked front?
Also, if anyone wants to weigh in as to whether longer sway bar links would be a good idea with this swap, that would be greatly appreciated. Thanks!
Old Nov 19, 2014 | 09:23 PM
stagedtrip's Avatar
Sway bar swap wouldn't be needed, but really wouldn't hurt either guess it would depend on how much lift you actually get. When I did the 14/54 to 18/59 I got 1 1/2 i n the front 1 maybe 1 1/4 in the back and it sat almost completely level
Old Nov 19, 2014 | 10:28 PM
Mad Dog 21's Avatar
Agreed^^^ I did the same thing and if it's not level it's really dang close. Plus, you might want the JKS swaybar quick disconnects later down the road anyways... Eitherway, I hope this helps you out if not I can show you some photos of its stance.
Old Nov 20, 2014 | 04:06 AM
thefourth's Avatar
Thanks for replies everyone. Is there a reason you guys went with 18/59 instead of 19/60? Would I be better off doing it that way?
Mad Dog 21, yes, if you have a pic that would be most helpful.
Thanks again guys!
Old Nov 20, 2014 | 05:18 AM
orangedude71's Avatar
Originally Posted by thefourth
Thanks for replies everyone. Is there a reason you guys went with 18/59 instead of 19/60? Would I be better off doing it that way? Mad Dog 21, yes, if you have a pic that would be most helpful. Thanks again guys!
my understanding is 19/60 are a rare bird but 18/59 are pretty common. My advice is its ok to start with either swap but eventually if you start putting a winch or armor on, it's all going to sag back to a raked look anyways. In two years you'll be looking for a front spring upgrade or a fresh set of 18/19
Old Nov 20, 2014 | 11:19 AM
Gman*2007's Avatar
I ran the 19/60 spring setup with a 3" spacer up front and 2" in rear. It sat level with front & rear LoD full width bumpers & winch up front. Welcome to the forum.
Old Nov 20, 2014 | 12:34 PM
metaldemon's Avatar
I have TeraFlex leveling pucks with 19/61 springs off a 4dr Rubicon. (I know I thought 60 was as high as they went) That is 2" spacer in the front and 1" in the back. With the springs and pucks it must be about a total of 2.5". That is with a winch and bumper. She sits pretty level.
Old Nov 20, 2014 | 06:10 PM
Mad Dog 21's Avatar
I just read your post but here is the stance.
Old Nov 25, 2014 | 04:05 PM
JerseyMark's Avatar
I did the 19/60s on my JKU - seems about the same rake as stock with a slight rake. After it settled - probably about a 1/2-3/4 taller front and rear and drives better. I didn't want to lose the Rake so it worked perfectly for me.
Old Nov 25, 2014 | 04:12 PM
catahoula's Avatar
For reference 18/59 springs and TF leveling kit 2" front 1" rear.
