1st time changing diff fluid question
Old Oct 17, 2014 | 10:56 AM
zedteamk2's Avatar
Default 1st time changing diff fluid question
I've found some good instructions and it looks pretty easy.
My question is this....
I don't have LSD ( according to my build sheet ), and all the oils i am finding have additives for LSD.
Can i use an oil with those additives? or do i need to look harder and find an oil without them.?
Thanks
Old Oct 17, 2014 | 11:08 AM
14Sport's Avatar
Yes you can use oil with the additive. Just not the other way around.
Old Oct 17, 2014 | 11:46 AM
rob_engineer's Avatar
Jeep recommends synthetic and a higher weight in the rear if you plan to tow. Someone on here said it is a little easier to reach the rear filler hole if you jack up the rear of the jeep slightly to raise the frame.
Old Oct 17, 2014 | 01:05 PM
crusaderJK's Avatar
I've used a drill pump to fill my diffs. Worked great.
Old Oct 17, 2014 | 01:45 PM
fultonromero12's Avatar
I used a hand pump from harbor freight. Best $5 I've spent there. Complete change of fluid in less than 30 min for both
Sent from my iPad using JK-Forum
Old Oct 17, 2014 | 01:56 PM
Invest2m4's Avatar
Why not just use the bottle the fluid comes in? That's why it has the pointy tip. Stick it in the fill hole and squeeze. Takes 30 seconds a bottle.
-Captain Obvious
Old Oct 17, 2014 | 04:44 PM
jeepmojo's Avatar
Default i totaly agree
-Captain Obvious
those pumps don't like to pump the heavy gear oil some times if its cold out . the bottle it comes in is the easiest
Old Oct 17, 2014 | 05:32 PM
14Sport's Avatar
-Captain Obvious
And that's what I did. That's why I bought 4 quarts instead of a gallon.
Old Oct 17, 2014 | 06:17 PM
pjmjk's Avatar
Depends on your diff covers too. I have teraflex covers had no issues just sitting underneath and using the bottle fluid came in
Old Oct 17, 2014 | 06:28 PM
tribulation138's Avatar
Those pointy bottles do not fit to pour into your differentials. Unless you want most of the oil on the ground.
Pep boys sells a hand pump that fits over empty windsheild washer 1gallon bottles. I use that. Just make sure its clean.
