2007 & 2008 Lifetime Limited Powertrain Warranty
Old May 16, 2012 | 08:23 AM
AirBorne82's Avatar
If I purchase a 2007 JK 2DR used is there ANY hope that the limited lifetime warranty will convey with the vehicle?
Old May 16, 2012 | 08:25 AM
ronjenx's Avatar
N'ope. (contraction for no hope)
If it's a separately purchased warranty by a previous owner, it may carry to you, though.
Old May 16, 2012 | 08:47 AM
joker23's Avatar
Originally Posted by jk-tony
And it only applies to the original owner
I bought my 2007 used from a Ford dealer last April with a 1 month/1,000 mile warranty. I thought the warranty was acceptable since it was a 4 year old vehicle with over 60K miles on it. They did replace a harness because the airbag light came on and stayed on.
Water pump started leaking, but I didn't realize it was the water pump right away, I thought it was condensation from running the AC. I got my hopes up when people started talking about the lifetime warranty from Jeep, then found out it was first owner only.
I was going to replace the water pump myself, but then it stopped leaking on its own. I'll probably still replace it, though. It's not too expensive and there are several threads about people having theirs go out around 30K, so mine may already be on it's 2nd and in need of a third...
Old Feb 11, 2013 | 04:32 PM
bigbull29's Avatar
Default Lifetime warranty on 08 Wrangler
It is actually 60 days prior to or after the 5 year anniversary...
Old Feb 11, 2013 | 06:05 PM
zstairlessone's Avatar
Mine is coming up in March. For anyone that has done this how long does it take and did you have to make an appt?
Edit: should I take off the CAI and put my OEM intake back on?
Old Feb 11, 2013 | 06:11 PM
justinstoffregen's Avatar
You need to make an appt because it takes a couple hours and the stealership needs to be very thorough. I didn't remove my airraid cai. It's kinda' irrelevant.
Old Feb 11, 2013 | 06:18 PM
Thanks, I put my AFe on because they couldn't replace an air filter without screwing it up (good reason )
Old Feb 15, 2013 | 06:21 PM
Rockroaster's Avatar
Anyone had any issues with going in for the inspection with axle modifications? I went in to mine today and they told me because my axles have been modified, it voids everything else as well, include engine , transmission, and tranny. I don't believe this is correct, but can anyone verify either way? I'm supposed to go back in for a reinspection in a few weeks because I didn't have my front driveshaft in as I'm currently replacing it.
Old Feb 15, 2013 | 08:14 PM
bkjeep's Avatar
Power train modification including non stock oil pans and such will disqualify you from future warranty coverage. Axle mods etc, most certainly.
Old Feb 15, 2013 | 08:16 PM
RedJeep91's Avatar
Wow, I did not know you have to take it in for the inspection. Mine hits 5 yrs this December. Thank you!
