2007 3.8L losing coolant
I was losing coolant at 30k on my 07 , no visible puddles on the ground but small drips of coolant were visible around the water pump, so I decided to put a quarter bottle of liquid gasket sealer in the overflow coolant tank and I now have 80k on it and haven't added a drop of coolant since. I believe in taking the pill before operating.
Liquid gasket sealer? Like Liquid Copper Stop Leak? I think I would only do that as a last resort.
I'm losing coolant on my 08 with 37k. It isint rapidly but prob since the beginning of summer. Maybe slightly before that. And every once in a while if I'm at a light I see a tab bit of smoke from the grill. No puddles or noticeable leaks. Should I be worried
My main question is that is it normal to lose coolant after time. I mean it's now 5 years old with 37k. And it does go off road on weekends and deals with nyc driving during the week when I take it to work. And I'm also a little hard on the pedal
I would say that for most cars , no it is not normal. A jeep , yes it is normal to lose some coolant after awhile but not 37k. I would address the issue somehow or you will be adding a lot of coolant over the years.
The solution is 50% water so evaporation can account for a little. But very little if everything is functioning. It's a normally closed system except for the expansion tank. But the cap could be failing. Is the upper hose collapsing when cold?
If you suspect a leak you can have it pressure tested. And at 5 years, it's time to replace that coolant if you haven't already. The 08s require HOAT coolant.
The mist rising from the grill is commonly seen during light rain or after splashing through puddles. Probably not coolant. Leaking coolant has a distinctive smell to it.
I don't use the jeep everyday. The last time I checked it wasent driven for 3 days. And the expansion tank level is below the minimum line. I have not checked the radiator level itself. I also recently took it out with a trailer a couple of times.
