2007 3.8L losing coolant
#34
Same thing happened to me at 40k. No problems with the pump since then.
I did develop a pin size hole in the radiator at around 60k, which was easily solved with those pellets you put in the radiator when the engine is cold.
#36
Thanks for the reply. Do you put it on both the pump and engine with the gasket in-between, or just on one side? Any reason for using 'Permatex The Right Stuff' versus regular RTV?
Reason I ask is because I've read a post of only putting it on the engine but not the pump. Just trying to get clarification.
TIA
TIA
#37
