2007 radiator fan low speed resistor
Old Aug 16, 2020 | 04:59 PM
OpenTrackRacer's Avatar
Default 2007 radiator fan low speed resistor
I noticed that low speed was no longer working on the radiator fan. In digging around I found that the thermal fuse had failed. The only option from Mopar is the while assembly. I've bypassed the thermal fuse for now but I'd like to replace it. Does anyone know the temperature value? I can't make out the numbers on the part.
Thanks!
Old Jul 2, 2022 | 06:28 PM
RCYJ's Avatar
Hi I'm having the same problem. Did you ever find the part? I'm having a hard time finding it. Thanks.
Old Jul 10, 2022 | 09:50 PM
I made a guess and did the repair but it didn't last. I ordered a new harness but just discovered that it's got the wrong pinout. Really annoying.
Old Oct 13, 2022 | 01:52 PM
Acsmith's Avatar
Default Any update?
I think my 2008 has the same problem.
Old Oct 15, 2022 | 05:28 PM
RCYJ's Avatar
I ended up buying part number 68048545AA and it fit fine but that didn't fix the issue. I found out that the there is bad ground coming from the harness connector. I bought I used one on eBay because a new one is $$$, but the pin was wrong. The pin is not hard to re-pin. You can find it on Youtube or try this
. Fan fixed,
