2007 Rubicon BFG Mud Terrain Tires
The Maintenance Schedule says to rotate every 6000 miles or every other oil change. Karina Barajas at Temecula Jeep said to do it every oil change which is every 3000 miles. Which is correct?
General rule is every other oil change or 6K miles, but it depends on how you drive and how much you take it off road. If you're airing down quite a bit to tackle trails, I'd probably rotate every 3K. If you're doing mostly city driving, every 6K should be fine
